Volvo 2.0 Turbo
by Ddub. 03/21/19 11:43 AM
Got a busted crankshaft!
by Chris142. 03/21/19 11:18 AM
Bad Motorcraft Plug?
by tmorris1. 03/21/19 10:47 AM
SAE 20 non-detergent oil
by fleetwood62. 03/21/19 10:39 AM
PSF3 in older Kia?
by Jetsfan421. 03/21/19 09:48 AM
USB WiFi adapter recommendations?
by Quattro Pete. 03/21/19 09:44 AM
m1,ep and valvoline.
by avi1777. 03/21/19 09:39 AM
540 RAT
by elpcmaster. 03/21/19 09:18 AM
Caliper recommendation?
by supton. 03/21/19 09:08 AM
Honda st1300 LED light
by Zuraxus. 03/21/19 08:26 AM
2001 CRV no restart when hot
by Kurtatron. 03/21/19 07:27 AM
Amazing human feats - free-diving...
by Shannow. 03/21/19 04:59 AM
How long to warm-up an engine?
by OilUzer. 03/21/19 04:58 AM
Disappearance and appearance
by bbhero. 03/21/19 04:38 AM
Big Changes for WIX 51334 - Pics
by tony1679. 03/21/19 04:26 AM
Supertech Synthetic Data Sheets
by The Critic. 03/21/19 04:25 AM
Forester XT filter recommandation
by jbutch. 03/21/19 04:23 AM
Taking the leap to self-employment.....
Eventually
by clinebarger. 03/21/19 01:39 AM
AlanGonzales, Jrealstreeter, DarkFrontier, Zuraxus, Burks21
67574 Registered Users
113 registered members (ad244, Aichiguy, 1978elcamino, addyguy, 69Torino, 2012AccentSE, 10 invisible), 1,931 guests, and 59 spiders.
Topics286,185
Posts4,903,775
Members67,574
Most Online2,967
Mar 10th, 2019
Page 1 of 5 1 2 5
2018 Camry I4 XSE 0W-16 #4571664
11/12/17 11:25 AM
11/12/17 11:25 AM
TN
kaminski54 Offline OP
TN
Hello All,
I recently purchased a 4-cylinder (a25a-fks) 18' Camry specing 0W-16 oil. Being that this is the first 0w-16 spec'd car in the US (at least that I am aware of), I figured a discussion was in order. The manual states that 0W-20 can be used but must be changed back to 0W-16 at next oil change.
I know I am overthinking it, but that is kind of why we belong to BITOG. I changed my factory fill oil at 1000 miles... looked perfectly fine with no metal flakes etc. I've seen before in a factory fill. I also cut open the stock filter... ridiculously clean. I am now convinced that an early drain is not needed.
I refilled it with TMGO 0W-16 from the dealer (about $7/QT) and a stock Toyota filter. I have researched as much as I can and just can't get over a 16 grade oil. Again I know I am overthinking, but I just keep wondering about such a light oil at prolonged highway speeds temperature and therefore viscosity-wise. I also am concerned about a 20 grade or 30 grade leading to increased bearing/piston/valvetrain temperatures due to lower flow or tighter tolerances at non-highway engine speeds.
Can engines really be built that have such tolerances and oil pathways that a 30 grade oil will be restricted in flow? If so, are these engines what we are now seeing? Is this just a ploy by Toyota to capture market share on oil until/if the big oil companies start mass producing 0W-16?
Any other thoughts, research, or recommendations?
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571667
11/12/17 11:30 AM
11/12/17 11:30 AM
South Central PA (Fulton Co)
Delta Offline
Delta  Offline
Well I'll be; they went back to a regular oil filter for this 4 cylinder.
'17 VW GTI 2.0T - 6MT - 14K - PPE 5w40
'15 Camry SE - 2.5 - 22K - PP 0w20
'99 S10 - 2.2 5MT - 159K - PP 10w30
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571669
11/12/17 11:31 AM
11/12/17 11:31 AM
Central Florida
Mr Nice Offline
Mr Nice  Offline
Central Florida
Good to see a spin on oil filter instead of silly cartridge filter.
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571678
11/12/17 11:42 AM
11/12/17 11:42 AM
USA
slacktide_bitog Online content
slacktide_bitog  Online Content
USA
interesting way to cut a filter open :czy:
AAP is starting to carry CQ Synthetic 0w16, made by Amalie/Wolf's Head. About $25 for 5 quarts and a "filter" (but you can always get a real filter at Napa or O'R)
I that one of those Made in Japan filters you can;t buy outside the factory?
Re: 2018 Camry I4 XSE 0W-16 [Re: Delta] #4571682
11/12/17 11:44 AM
11/12/17 11:44 AM
In the shop
53' Stude Offline
53' Stude  Offline
In the shop
Yeah, 4967 FRAM variant FYI smile
Re: 2018 Camry I4 XSE 0W-16 [Re: slacktide_bitog] #4571691
11/12/17 11:53 AM
11/12/17 11:53 AM
TN
TN
Yeah, It was late at night. Flat head screw driver and hammer to make a slit, then tin shears to cut an opening. It works.
This was the factory filter, but the replacement looked identical with the same part number.
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571692
11/12/17 11:53 AM
11/12/17 11:53 AM
Midwest, Illinois
beanoil Offline
beanoil  Offline
Midwest, Illinois
What does the engine spec in other countries, and 6 months from now, someone will have already run a thicker oil with no problems.
Valvoline Instant OMG has (seriously!) already put in an 0w20 or 5w20 somewhere.
Even your statement gives you a way out. The manufacturer support 0w20 if 16 is n't available. It isn't in so many places.....
beanoil: Tough under heat, real dirty afterwards.
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571693
11/12/17 11:54 AM
11/12/17 11:54 AM
PimTac Offline
PimTac  Offline
Is the OP our first BITOG 0w-16 user?
Cannot see signatures any longer so it doesn’t matter.
Re: 2018 Camry I4 XSE 0W-16 [Re: Delta] #4571706
11/12/17 12:06 PM
11/12/17 12:06 PM
Buffalo, NY
JTK Offline
JTK  Offline
Buffalo, NY
I hear that! Seems weird to take a step backwards.
The cartridge filter element was huge in comparison to that thimble sized spin-on as well.
2017 Ram 1500 4x4, 3.6L. 2016 Nissan Quest SV (Babe magnet IV)
Re: 2018 Camry I4 XSE 0W-16 [Re: beanoil] #4571707
11/12/17 12:07 PM
11/12/17 12:07 PM
TN
TN
I've been looking for a international spec chart but cannot find one. Would feel much better if I could see one.
Re: 2018 Camry I4 XSE 0W-16 [Re: PimTac] #4571708
11/12/17 12:07 PM
11/12/17 12:07 PM
TN
TN
Oh dear God... Please no.
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571744
11/12/17 12:40 PM
11/12/17 12:40 PM
Colorado
newtoncd8 Offline
newtoncd8  Offline
Colorado
According to the article below, they are seeing a 2-4% increase in fuel economy with 0W16 and are working on 0W8.
https://noln.net/2017/06/30/skinny-ow-16-oil/
12 Jeep GC, 04 Lexus RX330, 77 MG-B
11 Audi A4, 01 Audi A4
99 Lexus ES300, 98 Isuzu Trooper
94 & 91 Acura Integra, 88 Toyota Camry,
84 Honda Accord, 70 Pontiac LeMans,
62 Ford Galaxy 500
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571765
11/12/17 01:11 PM
11/12/17 01:11 PM
Wet side WA
JohnnyJohnson Online content
JohnnyJohnson  Online Content
Wet side WA
How long did it take to chew that open?
2004 Corolla 129987
Out: EDGE EP 5W-30 Bosch 3311 7156 Miles
In: Havoline Pro DS 10w-30 Purolator PureOne 3-14-19 129693
2006 Duramax 74725
Out: T6 5W-40 M1-303
In: T6 5W-40 XG9100 73705 4-22-18
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571771
11/12/17 01:21 PM
11/12/17 01:21 PM
Chicago / IN
vinu_neuro Offline
vinu_neuro  Offline
Chicago / IN
Progress never stops. There were similar fears with 0W-20 and it's common now for fleet engines to go past 500k mile mark on it. Congrats on the new car and trusting the engineers of your engine.
Re: 2018 Camry I4 XSE 0W-16 [Re: kaminski54] #4571781
11/12/17 01:32 PM
11/12/17 01:32 PM
Columbus,Nebraska
Yah-Tah-Hey Offline
Yah-Tah-Hey  Offline
Columbus,Nebraska
That's off of a 18 Camry? When did Toyota go back to a canister type oil filter? That's definitely a step back in the right direction.
Page 1 of 5 1 2 5
