Mixing oil
by DerekPho - 12/15/19 03:03 AM
Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
50 registered members (2015_PSD, 2002 Maxima SE, alcyon, AlienBug, 2009Edge, 7 invisible), 962 guests, and 18 spiders.
Topics298,820
Posts5,141,918
Members70,129
Most Online3,589
Nov 2nd, 2019
Page 1 of 4 1 2 3 4
Extension cords. #5139026 06/20/19 07:01 AM
Chris142 Offline OP
I need to upgrade my extension cords. The ones my dad left be are from the 50's and don't have the 3rd prong/ ground. As a young kid my dad showed me how to cut that 3rd prong off of the offending tool,how to put a penny under a fuse and how to wrap a fuse with foil.
So. I want to upgrade my extension cords and use them as designed. Where is the best place to buy them? I looked at Harbor Freight and they are expensive there. Or am I just out of the loop?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Extension cords. [Re: Chris142] #5139033 06/20/19 07:09 AM
A
ARCOgraphite Offline
A
I don't know if its cheaper to buy bulk wire and terminate yourself if you want 50' plus or buy pre-made they aren't killer expensive - unless you are running high amperage draw.
You don't want low grade copper - it ups the impedance and thus loss in the cord. Maybe bring a VOM to the store and check the OHMS/ft of what you are considering buying.
What are you running with these cords? Circular saws and such?
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Extension cords. [Re: Chris142] #5139034 06/20/19 07:10 AM
dlundblad Offline
eBay and Menards have cheap 14 amp cords. I guess it depends on what size, length and durability you want.
03 Jeep WJ 4.0 202k Edge 10w40 HM Fram XG16
02 Volvo S60 2.4T 195k M1 0w40 Mahle OX149D
97 Chvy Blazer 4.3 158k M1 EP 10w30 Supertech ST3980
Re: Extension cords. [Re: Chris142] #5139035 06/20/19 07:11 AM
E
E150GT Offline
E
I bought a 12 gauge 100' extension cord thinking bigger was better. Man that thing is a bear to haul around. I should have gotten a 14 gauge.
1984 Mercedes-Benz 300SD - 100k
1995 F150 XL 4.9 reg cab 5MT - 251k 5w30
2016 Mazda6 Touring 6MT - 68k 5w30
2006 Buick Lucerne CXL 3.8 40k 5w30
Re: Extension cords. [Re: Chris142] #5139036 06/20/19 07:11 AM
F
FlyNavyP3 Offline
F
I've found that extension cords are expensive. Especially when you get into 12 or 10 ga cords. 14 and 16 ga cords are cheap by comparison. I have yet to find a cord cheaper by the foot than harbor freight, I own some of their cords in 14, 12, and 10 ga inherited from a friend. My only other cords were made from braided wire with enroute on them for the job, which is probably the most expensive way to buy or build a cord.
If you buy from HF extension cords regularly go on sale and you can use the 20% off coupon on top of the sale price.
Luke
Re: Extension cords. [Re: Chris142] #5139038 06/20/19 07:15 AM
A
atikovi Online Content
Online Content
A
The only time you need a 3 prong cord is if the electrical item you're using has a 3 prong plug. Most lights and small tools like a drill don't. Using a 3 prong cord with a tool that has a 2 prong plus has no advantages.
Re: Extension cords. [Re: Chris142] #5139041 06/20/19 07:15 AM
E
EdwardC Offline
E
Like others mentioned, it probably depends on what you want to power, but you can't really go wrong with a thicker gauge wire.
This was a while back now, but I purchased a couple two packs of 50' 12awg extension cables from Costco that were made in the USA that were really well priced.
Re: Extension cords. [Re: Chris142] #5139044 06/20/19 07:17 AM
supton Offline
Are the ones from HF UL listed/approved/whatever? I've been leery of using any cords that aren't listed. I can be a cheapskate but only on things that I can watch in case of failure, and extension cords tend to get buried or loaned out and forgotten about.
Wife got a cheapo cord for the vac at church, but I swear they cheapened out on the prongs for the plug, they are slightly thinner than anything else I've ever used, and there is barely any drag on the plug when going into the outlet. It doesn't get hot (the cord that is) so I haven't complained.
What are the loads required? The bigger the amperage and the longer the run the lower the gauge (lower meaning fatter wire).
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: Extension cords. [Re: Chris142] #5139049 06/20/19 07:21 AM
E
EdwardC Offline
E
I also like the idea of extra flexible cold weather cords for ease of coiling in all temps, but haven't really had a need.
Lighted ends are a nice bonus too.
Re: Extension cords. [Re: Chris142] #5139055 06/20/19 07:36 AM
Donald Offline
Northern has them on sale from time to time. A 12 gauge is overkill when you only need a 60 watt lightbulb. And a 100' extension cord will have more voltage loss if you only needed 25'.
Typically the cheap part of an extension cord is the ends.
Buy an extension cord, plug in a space heater for 15 minutes and point your IR tool at the ends and see if either heated up.
2015 Ford F250 w/Powerstroke
Re: Extension cords. [Re: Chris142] #5139061 06/20/19 07:43 AM
B
bmwpowere36m3 Offline
B
Flexzilla.... great quality, flexible, bright color, lit ends and not expensive.
Re: Extension cords. [Re: Chris142] #5139065 06/20/19 07:46 AM
T
tmorris1 Offline
T
The size depends on what you are using it for. Air compressor, get a 12gauge, it you are running low current devices get a 14 or 16 gauge that is cheaper and lighter. The longer you go, the heavier you need too.
Re: Extension cords. [Re: Chris142] #5139082 06/20/19 08:16 AM
Chris142 Offline OP
Just low currant things. The power company was working in our area yesterday and the power was off all day.I wanted to plug in my refrigerator amd Microwave (3 wire plugs) into my generator but couldn't.
Re: Extension cords. [Re: Chris142] #5139083 06/20/19 08:18 AM
Char Baby Offline
I believe Harbor Freight has a good selection of 10, 12, 14 & 16 gauge extension cords in several lengths(25'-100'). And can most likely be purchased with their 20% Off Coupon.
"Retired"
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Extension cords. [Re: Chris142] #5139084 06/20/19 08:23 AM
E
EdwardC Offline
E
I'd argue that those are both fairly high current devices, I'd go 12 gauge in the 50'-100' range.
Page 1 of 4 1 2 3 4
