Toyota factory pink mixed with zerex coolant
by Rohan. 04/21/19 04:48 PM
Schaeffer 204SAT and 205A
by Gebo. 04/21/19 04:32 PM
Oil for old Chevy TBI 350
by RonRonnster. 04/21/19 04:19 PM
2012 chevy equinox transmission fluid
by krdoss. 04/21/19 03:50 PM
How Often Change Fuel Filters?
by Gebo. 04/21/19 03:17 PM
New Hyundai Elantra tell me all I need to know
by DONWATERS. 04/21/19 02:28 PM
How much balance weight is too much
by Hitman70. 04/21/19 02:02 PM
bought steel cut oats by mistake
by andyd. 04/21/19 01:50 PM
Mobil1 Synthetic Lubricating Spray
by EvanR. 04/21/19 01:01 PM
List of cars you've owned
by SLO_Town. 04/21/19 12:30 PM
Email Notice
by borgward. 04/21/19 12:14 PM
Why would 10w burn more than 5w?
by D1dad. 04/21/19 11:57 AM
02 Silverado 5.3L, LT, Low Oil Pressure
by Gito. 04/21/19 11:54 AM
0 to 60 in 1.9 seconds...
by JeffKeryk. 04/21/19 11:16 AM
Luxury Car Owners Switching to Pickup Trucks
by SubLGT. 04/21/19 11:05 AM
Easiest Way to Gravity Bleed Brakes
by jims5600. 04/21/19 10:55 AM
Newcastle Brown Ale replacement?
by Reddy45. 04/21/19 10:31 AM
Easter Sunday
by gman2304. 04/21/19 10:17 AM
Old Buick Century Question
by GrtArtiste. 04/21/19 10:03 AM
Texas72, RamblerReb, rchapin, js1956, krdoss
67865 Registered Users
92 registered members (2015_PSD, AndyB, 53' Stude, andyd, alphadog, 2dogs, 11 invisible), 1,928 guests, and 26 spiders.
Topics287,853
Posts4,935,600
Members67,865
Most Online2,967
Mar 10th, 2019
Oil consumption #4724756
04/12/18 01:56 PM
04/12/18 01:56 PM
FL, USA
shurguywutt Offline OP
FL, USA
Have a 2008 Honda with 145k that is consuming oil. I have used Mobil 1 synthetic, redline, royal purple, valvoline synthetic, valvoline high mileage synthetic etc. All oils seem to be consumed about the same. Mostly used 5w-20, 0w-20, even tried 5w-30. Would consume about 1qt per oil change. I thought I might try some Valvoline Synblend high mileage 10w-30 but it seems to be consumed even faster about half a qt after just 1000 miles. this seems very excessive. Any advice or recommendations? I may just switch back to 5w-20 valvoline synthetic or synblend high mileage as it doesn't seem to make a difference anymore. Thanks
2008 Pilot 2WD J35Z1 153k
Shell 5w-30
Re: Oil consumption [Re: shurguywutt] #4724769
04/12/18 02:06 PM
04/12/18 02:06 PM
NY
demarpaint Offline
demarpaint  Offline
NY
You could need a PCV valve, or stem seals, or a piston soak because rings are sticking, all three, or there's engine wear. Lets not forget a leak, although you'd probably see it. I'd start with the easiest first and work my way up from there. FTR Honda would consider your consumption normal for the miles on the vehicle.
God Bless Our Troops
Re: Oil consumption [Re: shurguywutt] #4724779
04/12/18 02:16 PM
04/12/18 02:16 PM
S California
OneEyeJack Offline
OneEyeJack  Offline
S California
+1
Re: Oil consumption [Re: shurguywutt] #4724781
04/12/18 02:17 PM
04/12/18 02:17 PM
Ontario, Canada
mightymousetech Offline
Ontario, Canada
On top of what was said above, which is spot on, what oil change interval was used on the vehicle?
Mighty Mouse Tech
BMW Tech, Former Acura Tech
2010 Civic Si Castrol 0W40, Redline MTL
2013 BMW 135i M Sport Edition Castrol 0W40, Redline MTL
Re: Oil consumption [Re: mightymousetech] #4724792
04/12/18 02:25 PM
04/12/18 02:25 PM
FL, USA
FL, USA
I follow the maintenance minder. Probably ever 5-8k. I check my oil often however, and top off as necessary.
Shell 5w-30
Re: Oil consumption [Re: demarpaint] #4724799
04/12/18 02:32 PM
04/12/18 02:32 PM
FL, USA
FL, USA
Thanks for the reply demarpaint, I have already replaced PCV, ran seafoam through the engine brake booster line, and there is no leak. How do I go about doing a piston soak and stem seals? Can this be done during a valve adjustment by the shop? How much should I expect to pay for this? I have a good Honda certified mechanic I can use. Thanks for the info.
Shell 5w-30
Re: Oil consumption [Re: shurguywutt] #4724800
04/12/18 02:32 PM
04/12/18 02:32 PM
Ontario, Canada
Ontario, Canada
Good thing you keep it topped off, that is the real killer with the Honda V6. May want to try shortening the OCI and see if that helps.
Mighty Mouse Tech
Re: Oil consumption [Re: shurguywutt] #4724802
04/12/18 02:33 PM
04/12/18 02:33 PM
MA USA
andrewp1998 Offline
andrewp1998  Offline
MA USA
try a 0w 40 syn
2001 Honda civic HX vtecE- 5 spd.
Re: Oil consumption [Re: shurguywutt] #4724803
04/12/18 02:35 PM
04/12/18 02:35 PM
OH
SatinSilver Offline
SatinSilver  Offline
OH
Try a stout conventional Xw30 like Formula Shell at Home Depot on sale for $9.88 till 4/15. Five qt. jug also. Replace pcv valve with an oem unit. Usually the spring breaks around the 60k mark.
Does this thing have vcm? If so disable it with a vcm muzzler. <-------- Please google it.
Re: Oil consumption [Re: SatinSilver] #4724819
04/12/18 02:46 PM
04/12/18 02:46 PM
FL, USA
FL, USA
Yeah, pcv is replaced, not with oem unit however. It does have VCM but I disabled it a long while back. Did not change oil consumption however. Also, most of my mileage is highway which seems to speed up the oil consumption rate.
Shell 5w-30
Re: Oil consumption [Re: shurguywutt] #4724825
04/12/18 02:52 PM
04/12/18 02:52 PM
Canada
camrydriver111 Offline
Canada
That's what I would do. If it burns oil just use whatever.
Maybe I would run HM for a few oil changes and see if running it over a period of time helps.
BITOG or: How I Learned to Stop Worrying and Love the Extended OCI
Re: Oil consumption [Re: shurguywutt] #4724833
04/12/18 02:56 PM
04/12/18 02:56 PM
RI, USA
plf Offline
plf  Offline
RI, USA
was noticing the same with my 2010 honda CR-v 127,000 miles on it. when using Mobil 1 @7,500 oil changes. Switch over to Quaker State 0w-20 full syn and does not consume much at all. Not sure why but noticed less consumption and have used it on my last 5 oil changes
2010 Honda CR-V, QS 0w-20
2014 KIA Optima LX, ST full synthetic 5w-30
Re: Oil consumption [Re: shurguywutt] #4724836
04/12/18 02:57 PM
04/12/18 02:57 PM
Spring,Texas
Bud_One Offline
Bud_One  Offline
Spring,Texas
I'd try 10W-30 ,it slowed down consumption in my old Accord and my old Vibe I used to have.
16 Civic-QSUD 0W-20, XG7317
14 Civic-Idemitsu Zepro 0W-20, XG7317
05 Chevy 2500HD-QSUD 10W-30, XG3675
97 Accord Wagon-Havoline ProDS 10W-30, TG7317
Re: Oil consumption [Re: shurguywutt] #4724837
04/12/18 02:58 PM
04/12/18 02:58 PM
SACRAMENTO, CA
rrounds Offline
rrounds  Offline
SACRAMENTO, CA
Check the compression and get a leak down test done. That will tell you how your rings and vavle guides are.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
Re: Oil consumption [Re: shurguywutt] #4724840
04/12/18 03:01 PM
04/12/18 03:01 PM
PA
ridgerunner Offline
ridgerunner  Offline
PA
U live in Florida so how about a straight SAE 30? Shouldnt burn off as much as a multi weight oil.
