quote:
Originally posted by kev99sl:
Just a general comment after reading some replies to the original post, since this is one of my (admitedly many) pet peeves.
The way some folks approach troubleshooting a problem makes me chuckle.
Here's a hint: if a person changes his oil, and immediately notices a 4 MPG drop in mileage, sluggish performance, and a louder engine, guess what? The oil should actually be the first on the list of suspects, not the very last. Not fuel. Not air filters. Not headwinds and tailwinds.
I understand that there are all sorts of variables that go into ascertaining what may be causing a change in performance, but doesn't logic dictate to all reasonable human beings that the one and only variable that was verifiably changed should be the first avenue of investigation? Uh, yes. It is very likely that, given time, this oil will be just fine in this application. But it is also very likely that it is indeed the oil that is causing these changes.
All other factors, outside of the one and only factor actually, deliberately changed, come in whatever order you please after ruling out that one and only factor that was actually, deliberately changed.
