Hey ravl,A wild guess to try to be helpful ( as it seems the oil control rings may be carbonized in some way, from what I could gather): pour GM top end cleaner into the spark plug holes and let it sit overnight. It should seep through to the sump. Change the oil the following day and then start the car. Let it warm up but then drive it hard - the top end cleaner may have freed up the rings enough to let the combustion process blow out the deposits, so to Speak. If this is off base, just disregard. i admire someone who doesn’t just throw in the towel. Good luck!
I have had the same train of thought and you are not off base by any means. I am going to follow my current plan of attack and go one more round when a complete oil change is due and see what the results are. It might be I just have to stick it out till the results get better.
I always said one thought leads to another when in a group discussion. Never hold back on your thoughts.
