Originally Posted by Mad_Hatter
Originally Posted by Shannow
You stated that the oil was a coolant...I countered that with what ACTUALLY happens.- this is the 2nd time you've attributed something to me that I didn't say. What I said was, "oil acts like a coolant" and not, "oil is a coolant". It's weird because while the coolant and radiator fulfill the principle role of keeping my engine cool, the oil in my engine also picks up heat as it passes through the engine and let's it go into the atmosphere via the oil cooler. Your oil doesn't function similarly?
Oh, and it's not the "little more throttle", as the heat is related to RPM, not power output. - weird..in my car, whenever I give the engine gas the rpms go up...how does it work in your car?
OK, I am typing very very very slowly now...
The majority of the heat that the oil transfers to the atmosphere is generated within the oil...not "picked up"... in fact the bearings transfer heat INTO the block to be "picked up" by the collant...
Look at the charts, and my previous posts...typing in red doesn't makeyou more understandable, or change what you said.
