Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
108 registered members (aircooled, 2000ltdken, 928, ajchien, 1WildPig, 72te27, 7 invisible), 2,378 guests, and 32 spiders.
Topics300,398
Posts5,174,917
Members70,497
Page 5 of 9 1 4 5 6 9
Re: Restore Experiment [Re: Vikas] #2932562 03/08/13 12:15 PM
P
Phishin Offline OP
P
Originally Posted By: Vikas
Phishin, do you have pre-Restore compression readings? Your empirical evidence of reduced oil consumption in itself is enough but the change in compression will corroborate better running of ht engine.
Sure do. I'll have to find it, but if my memory serves me right, Cylinder #1 was 105psi, and #2-8 was between 140-150. I also have the leak down test results as well.
But I have actual numbers in my log book.
2018 Chevy Silverado 3500HD 6.0L Gas: RLI 10w30
2010 Accord-LX K24: MaxLife 5w30 + Torco MPZ
2014 CR-V LX K24: M1 0w30
Re: Restore Experiment [Re: Phishin] #2932564 03/08/13 12:16 PM
T
Trajan Offline
T
Originally Posted By: Phishin
Of course, I expected to hear the AutoRx cheerleaders give their victory cry. I get tired of the AutoRx pollution in every thread too in this sub-forum, but it just digs them deeper into the grave, I think. Makes them look desperate.
Turnabout is fair play they say. Every ARX thread gets the same pollution from all thsoe who don't like the product/creator. Makes them look even more desperate. Especially when they make claims like "The company is failing.", but have no proof. Or how they claim long time members are shilling it.
But I digress. Leaving aside the fact I myself haven't used the product for a long time, it worked where everything else, mmo/rislone/restore, failed. I have to wonder why you keep coming up with excuses trying to explain away what I saw.
It has been lamented by some how people are not allowed to discuss oil adds whether they worked or not. So, why are you trying to stifle such?
It worked for you, you say. Good, I'm happy for you. It didn't work for me. It didn't do what it claimed it does.
If you're going to complain about how people post that it doesn't work, and with nothing approaching the malice the latest arx threads draw, then one can make the case that you're promoting a non sponsor product. Which will get this thread locked.
No oil add works for everyone.
Re: Restore Experiment [Re: Trajan] #2932631 03/08/13 01:35 PM
P
Phishin Offline OP
P
Yep, that was my point too. No malice from me. AutoRx worked for you for some unknown reason and Restore worked for me for some unknown reason. We're equal.
I wasn't bashing AutoRx. Never have. I was just commenting how I knew someone would come into my "Restore Thread" with a plug for AutoRx...and it doesn't really bother me. Honestly. I'm glad I can go to any store, buy a can for $8-$9 and have my truck run so much better for the next 5k miles. I like that.
Re: Restore Experiment [Re: Phishin] #2932676 03/08/13 02:36 PM
J
JavierG Offline
J
I wholeheartedly agree. And thanks for posting this thread. It's always good to hear when a product lives up to its claims. And I have no reason not to believe you. thumbsup
2007 Honda Ridgeline RTX - 143k mi - Kendall Semi-Syn 5W30, Fram HM filter
2016 Honda Civic EX-T Coupe - 42k mi - Mobil Super Syn 0W20, Napa Platinum
Re: Restore Experiment [Re: Phishin] #2932800 03/08/13 04:22 PM
V
Vikas Offline
V
I will ask once again. So what harm is done if you have to use this $8 product at every oil change?
Re: Restore Experiment [Re: Vikas] #2932821 03/08/13 04:36 PM
T
Trajan Offline
T
I'm not sure myself. I used it for four oil changes before I concluded it did nothing worthwhile. According to it's site, you use it at *every* oil change.
I find this curious though:
What about using RESTORE with "High-Mileage" motor oils?
Those types of motor oils are simply higher viscosity oil that cost more money. We recommend using a premium quality conventional motor oil.
Is RESTORE compatible with synthetic oil?
Yes, RESTORE may be used with any type of mineral or synthetic motor oil.
So which is it? Do you use a premium quality conventional oil?
Is that why it didn't work for me? Because I didn't use a premium conventional oil?
If so, then why say you can use it with synth oil?
Re: Restore Experiment [Re: Trajan] #2932833 03/08/13 04:46 PM
K
KeMBro2012 Offline
K
It's similar to Kool-Aid recommending you mix their product with water. Of course you can mix it with vodka, but you won't have quite the same result as if you use it as directed. The point they were making there was that it won't cause problems if you use their product with a synthetic oil, but they recommend using conventional for best results as per their own testing.
As for why it didn't work for you, I'm pretty sure that's been addressed in this thread already. Just in case I'm thinking of another thread or you're too lazy to scroll up and read it again, here it is:
ARX "cleans ring packs" while Restore fills in small scratches in the cylinder walls. If your poor compression was the result of stuck rings, of course a product not intended to address that particular issue is not going to work. Do you put a band-aid on a 6" long cut that's gone clear through to the bone and wonder why it didn't heal, as well? Does that mean band-aids aren't effective? No, it just means maybe what you actually need is a few stitches. Likewise, where ARX wouldn't work in cases where Restore would, stitches would do more damage to the skin than the small types of cuts band-aids are intended to be used on, thus they would not be appropriate in that situation. See what I'm getting at here? They both have their uses and there is little to no overlap between them.
Can we stop this bullsh*t infighting between additives? Just because one works for you doens't mean the others are [censored] and just because one doesn't work for you doesn't make it [censored], either. IF it works for you, you had the issue it was designed to solve, if it doesn't, you didn't. OF course, there are exceptions, and quite a few of them, but in those cases you'll be hard pressed to find anyone saying it worked.
Re: Restore Experiment [Re: Trajan] #2932847 03/08/13 04:58 PM
E
electrolover Offline
E
Your just grasping for anything to discredit restore. It comes off as desperate and a little pathetic.
Its full of soft metals so its not something for an engine in good shape. Its just a bandaid to keep you from bleeding out before you get to the Dr. It does it's job
Re: Restore Experiment [Re: electrolover] #2932893 03/08/13 06:01 PM
M
Mystic Offline
M
I have never used Restore myself. I am a member of the NRA and I see it advertised in the American Rifleman magazine a lot.
My view is this: If you have an engine in a vehicle that is smoking, using a lot of oil, and not running very well, and maybe close to the auto graveyard, what harm is there in trying Restore? If it will keep an old vehicle on the road for a while, reduce oil consumption (maybe paying for itself right there) and enable a person to get some thousands of miles of additional service then why not use it?
Especially if it costs only about $8.00 a bottle and maybe saves more than that or close to that in reducing oil consumption. Just makes sense to me.
Now I would not use it in a vehicle that was still in decent running condition. But if a car or truck is almost ready anyway to go to the auto graveyard why not?
Re: Restore Experiment [Re: Phishin] #2932931 03/08/13 06:38 PM
T
Trajan Offline
T
In light of how EM makes a HM 5w-20, perhaps they should rethink their Restore info.
Re: Restore Experiment [Re: Mystic] #2933017 03/08/13 08:04 PM
demarpaint Offline
Exactly! It is a specialty product, a difficult concept for some people to grasp.
God Bless Our Troops
Re: Restore Experiment [Re: Phishin] #2933086 03/08/13 09:00 PM
V
Vikas Offline
V
So according to you it is truly a last ditch effort i.e. try it before junking or overhauling the engine? If the engine still has life left in it, putting Restore will rob its life?
Re: Restore Experiment [Re: Vikas] #2933087 03/08/13 09:04 PM
K
KeMBro2012 Offline
K
It may not shorten the life of a decent-running engine, but it won' do it any good, either. Shades of gray, people.
Re: Restore Experiment [Re: Vikas] #2933088 03/08/13 09:10 PM
T
Trajan Offline
T
But if it does, the can claims it will restore such life.
Here's some back and forth on it: http://www.ripoffreport.com/auto-parts/restore-engine-oil-a/restore-engine-oil-additive-pr-a2nc3.htm
Re: Restore Experiment [Re: Vikas] #2933121 03/08/13 09:53 PM
demarpaint Offline
Yes in some cases it is a last ditch effort. How would putting it in rob life from an engine that has obvious problems? It fills scored cylinder walls in oil in worn or damaged engines, it raises compression if compression is being lost to bad rings and scored cylinder walls. It reduces oil usage in those cases.
If you have none of these problems, why would you use it would be a better question.
