Originally Posted By: Trav
It really doesn't matter if 20% or 50% get past it does it. It still gets past it to do damage if there were even any to begin with.
So much for clean oil as you claimed in another thread, if the filter is allowing 20% of the damaging particles through you can hardly call that clean.
Hypothetical how many 5 micron particles out of 100 are enough to do damage and to what extent, 10? 20? 50?? Prove it makes a difference.
The bottom line, which you don't seem to believe, is that cleaner oil results in less engine wear. Every study ever done comes to the same conclusion. For myself, I like to keep the oil as clean as possible, regardless of how much crud I thing there may or may not be in the oil. I'm not continually measuring the oil cleanliness in real time, so I just elect to use a very efficient filter so I know whatever is in the oil is mostly being caught by the filter.
And tearing down an engine and not "seeing" wear, or finding that dimensional measurements are still within FSM spec range is not a true way to determine the actual wear. There may still be some wear going on to some degree even with a high efficiency filter, but certainly at a lower rate that with a low efficiency filter.
People that understand filtering efficiency, oil cleanliness and wear will continue to use high efficiency filters ... those who don't will say it doesn't matter. Whatever floats your boat.
