No, This is not a Purolator only problem. We see this type of wide pleat tearing with other brands too.It is when it's made by Purolator/M+H, like this one is.
Purolator is the OE. It is a purolator problem. If its tearing even with good pleat spacing and density it could be a media formulation issue. The filter saw 4k and torn a pleat. Just saying. Mobil1 is the private label so they have no direct QC other than to complain to purolator their filters are crap and to get their engineering and QA to right it. Bad batches happen all the time manufacturing that will always reach retail stores no matter the product.These Mobil 1 filters aren't a very good value to begin with. That type of tearing is not just a Purolator problem either like some claimed.
Again, for the third time my statements are correct. I know who makes these for Mobil 1. This type of tear is seen on several other brands too w/wide pleat spacing around the seams. This type of tear is not inclusive to Purolator only period.Purolator is the OE. It is a purolator problem. If its tearing even with good pleat spacing and density it could be a media formulation issue. The filter saw 4k and torn a pleat. Just saying. Mobil1 is the private label so they have no direct QC other than to complain to purolator their filters are crap and to get their engineering and QA to right it. Bad batches happen all the time manufacturing that will always reach retail stores no matter the product.
Purolator/M+H made filters are far ahead in the race of torn media. Seems their media can't take much bending stress, and when that's combined with wide pleats plus oil dP they tear easy. There are lots of filters posted here that have wide pleats and they don't tear. Having wide pleats is only one factor involved in the media tearing equation.No, This is not a Purolator only problem. We see this type of wide pleat tearing with other brands too.
Purolator is probably going to be up there since it's a very popular filter brand so we'll hear about it more frequently.Purolator/M+H made filters are far ahead in the race of torn media. Seems their media can't take much bending stress, and when that's combined with wide pleats plus oil dP they tear easy. There are lots of filters posted here that have wide pleats and they don't tear. Having wide pleats is only one factor involved in the media tearing equation.
Not nearly as popular here as it use to be. If it was as popular here as before, we would probably see a lot more instances of media tearing.Purolator is probably going to be up there since it's a very popular filter brand so we'll hear about it more frequently.
Best I can recommend is make a spreadsheet, of torn filters, then you'll know if they're not as popular as you say.Not nearly as popular here as it use to be. If it was as popular here as before, we would probably see a lot more instances of media tearing.
There was a spreadsheet made by a member here back when the tearing was going wild, and it wasn't pretty. Even back then, there were people trying to make excuses for why the media was tearing. It's pretty obvious why, and the formulation of the media (it's flexibility and strength under stress) is a big factor when it comes to wide pleats with causes them to bend from the dP of oil flow. The pleat that tore on this filter wasn't even spread very wide compared to how wide some other filter's pleats are spread open next to the seam.Best I can recommend is make a spreadsheet, of torn filters, then you'll know if they're not as popular as you say.
I've seen that old one before. But this Purolator/Mobil 1 shouldn't have failed just like any torn filter should not have failed.There was a spreadsheet made by a member here back when the tearing was going wild, and it wasn't pretty. Even back then, there were people trying to make excuses for why the media was tearing. It's pretty obvious why, and the formulation of the media (it's flexibility and strength under stress) is a big factor when it comes to wide pleats with causes them to bend from the dP of oil flow. The pleat that tore on this filter wasn't even spread very wide compared to how wide some other filter's pleats are spread open next to the seam.
True ... and that's my underlying point too. So the question is why did it fail when it shouldn't have failed, which is the same question asked about anything that fails in service.I've seen that old one before. But this Purolator/Mobil 1 shouldn't have failed just like any torn filter should not have failed.
Im pretty sure mobil1 filters are the most popular in the aftermarket just by the name branding alone. Every normie car diy guy i talk to at the local parts store is their first pick outside of OEM. And yes many of them avoid Fram beause of the orange can myth and legend lol.Purolator is probably going to be up there since it's a very popular filter brand so we'll hear about it more frequently.
I've only ever bought 2: M1 212A filters. Posted both failures. I wouldn't chance itWell that's a bummer. I just bought one of these last week. Thanks for sharing.
Hi Mewbs,Im pretty sure mobil1 filters are the most popular in the aftermarket just by the name branding alone. Every normie car diy guy i talk to at the local parts store is their first pick outside of OEM. And yes many of them avoid Fram because of the orange can myth and legend lol.
That aside its just an overpriced run of the mill filter that can be had for less by other competing brands and labels.
Cellulose Synthetic blend is nothing special and is common in low end aftermarket offerings, sometime with better efficiency than mobil1 branded
