Originally Posted By: hatt
What's your question? We know if you abuse equipment it won't last. What about when you take care of it adequately.
No question. You are the one saying how expensive it is to repair these "complicated engines" or that "replacement is not an option because it is so expensive". And I pointed out it's not much more than the new 5.0. They are both expensive!
When you take care of it adequately it will give you long service life. Which, after 5 years we are seeing from the Ecoboost. Remember, a version of it came out in 2009 for the cars - SHO, MKS, Flex, MKT.
Quote:
Bottom line is that a twin turboed direct gas injection engine has a lot more stuff to go wrong than more conventional offerings. Just one example. What are the valves going to look like after 100K of short trips? No one knows.
Sure they have more things to go wrong. So does the 5.0 in your truck. I've got 2 turbos to worry about and that's about it - there is still advanced electronics, VCT, etc. in both engines. We know the EB is built stout so the mechanicals are up to the task.
I could care less what the valves look like at 100k. it's how the engine performs. According to one catch can salesman on the f150 forum I frequent, my SHO should have gummed up valves, no MPG and be pretty much dead by now cause I don't run a catch can. Guess what? MPG is the same as it was when new (and I have all the records to prove it), it drives perfect, and goes like stink.
Living in constant fear of the new must suck - those miss out on some truly great stuff.
