Originally Posted By: nleksan
Just let me know if there is ANYTHING you need to know. As you know, I have essentially taken my entire car apart and put it back together a couple times
The M52tuB28 is a fantastic engine, internally it is incredibly similar to the 96-99 US M3 S52B32, and it is a great engine to tinker with and is very easy to get a bit of extra power out of for very cheap (relative to M54 and beyond N/A motors), with an AFE Stg1 intake and Conforti Shark Injector showing over 15whp gain in 92*F weather on my car with zero other mods. Headers and an exhaust do wonders too, as do Underdrive Pulleys and once all that is done, a bigger TB (get a used Dinan).
If you need any maintenance help, I would be more than happy to help.
Now, first things first...
1) RP or RL 5w30/40 and OE or KN Oil Filter
2) Redline D4 ATF in gearbox and PS
3) RL 75w90 in diff
4) Motul RBF600 in brakes
5) OEM NGK Spark Plugs and Bosch boots
6) OE Fuel Filter
7) OE Charcoal Cabin Air Filter
8) Check battery and replace w Odyssey ltw battery if new is needed
9) Replace "guibo"
10) Start saving for suspension bushing overhaul w Powerflex Polyurethane bushings
11) Run RL SI-1 every other tank for a few thousand miles
12) Seafoam Deep Creep for TB cleaning and EGR/PCV/SAP cleaning
13) Flush Coolant and replace with BMW Coolant and 1btl RL Water Wetter for the extra 5s it will give you in case of part failure
That should have it running like new, although the suspension is probably getting worn. I would go with KW V1 or V2 coils and Rogue Engineering RSMs, as Bilstein and KYB Yellows just do not feel right to me. StopTech Stg2 brake upgrade is a great deal at 599 for 4 slotted discs, StopTech Street Performance pads, ST SS lines, Motul RBF600 x3, etc.
I think you just got a little too excited there, LOL!!
I have the M5 for the "fun stuff", this car is for my wife, so it isn't getting any performance mods.
OE filters it will get, oil will be Mobil 1 0w40, same as the M5 gets.
Battery is OK, coolant will likely be changed at some point in the spring.
I was advised the bushings were looking worn by the mech that did the safety, though there wasn't any play, as everything passed. So I'll keep those components in mind.
BTW, my sister has a few Dinan parts on the her 330i, including their TB. It gets up and scoots quite well. IIRC it has the TB, CAI and tune on it.
For the most part, since I get a good deal on BMW parts, that's what it is going to get.
Sorry to disappoint
3) RL 75w90 in diff
6) OE Fuel Filter
9) Replace "guibo"
Sorry to disappoint
