Originally Posted by MCompact
BMW free maintenance is no longer transferable to a subsequent owner.
Seriously? When did that happen?
mightymousetech said:The only common issues we see on the X3 is they tend to really eat up the front tires. I try to reduce the front the front toe to the absolute minimum of spec, but that seems to only reduce the issue, not eliminate it.
Can the 1 liter of fluid or whatever minuscule amount found in the front transfer case be changed? I remember reading that there's no drain plug and the unit has to actually be removed to change the
You can use a pump to remove the old fluid and then put new in.
