Originally Posted By: Gokhan
No, Total Quartz 10W-40 is a full synthetic. That was already discussed elsewhere. Please read it first before you claim otherwise.
Mobil 1 0W-40 is probably a combination of Group III+, IV, and V -- with no Group III. Group III is used in 5W-40 HDEOs, which are significantly cheaper.
The tests they did are actually quite similar to "hot-tube tests," which are standard for testing expected performance in a turbocharger-equipped engine -- the most demanding kind of engine. It's the crucial part of the Honda/Acura HTO-06 etc. tests.
The MRV value for M1 0w-40 increases with every re-formulation which leads to believe they are removing PAO from the formulation. This also has been discussed elsewhere.
Total Quartz 7000 is their mid-range product, often labelled as "synthetic-based". As the term synthetic is used so loosely, it's not really relevant wheather its group II+, III or III+.
If base oil quality reflects on the hot-tube test results, why did Motul 300V and Redline race oil do so badly? Both should be PAO and esters and therefore superior to M1 and Total. This was the point I was trying to make with my first post.
