Help with iphone on the home network
by buck91
05/06/16 06:45 AM
2003 lesabre battery change back seat type
by snake123
05/06/16 05:43 AM
Penrite 0w-16
by toyota62
05/06/16 03:31 AM
Land Cruiser stuck in mud, rescued by hemi Jeep
by Shannow
05/06/16 02:53 AM
GM to test self-driving taxis
by xfactor9
05/06/16 01:09 AM
Resurfacing Brake Rotors
by The Critic
05/06/16 12:02 AM
Largest M1 filter for Jeep 4.0
by ARMY_Guy
05/05/16 10:50 PM
Mobil 1 or Castrol edge?
by sky06
05/05/16 09:48 PM
1 piece lug nut recommendations?
by dlundblad
05/05/16 09:07 PM
1996 Chrysler Coolant
by outoforder
05/05/16 09:02 PM
Hat Tip to RMEuropean
by sleddriver
05/05/16 08:54 PM
Toro OHV considered flat tappet type...
by Duffyjr
05/05/16 08:48 PM
waldawg, Defcon, drivingaford, funkyheff, Ralph62
57814 Registered Users
76 registered (askani79705, AirgunSavant, aquariuscsm, 97f150, Asterix, 2015_PSD, 9 invisible), 0 Guests and 1 Spider online.
57814 Members
66 Forums
248539 Topics
Page 1 of 2 1 2 >
#3390789 - 06/06/14 03:06 PM 1997 BMW M3, oil?
stancyeze Offline
Loc: Northern Virginia
Hello, as stated above, I have a 1997 BMW M3 and I have heard about people using diesel engine oil in there M3's.. how is that good? 10W40 Shell Rotella is what I've heard is used. I just bought oil. Mobil 1 15W50, but I want to try something new..
Any thoughts? Was using 5w40 Motul before.
#3390826 - 06/06/14 03:43 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
tudorart Offline
Loc: Transylvania, Romania, EU
Motul is cheap and deceiving.
I think a 50 weight is too much for you unless is a 0W or a 5W....but it really depends on your engine's shape.
#3390827 - 06/06/14 03:46 PM Re: 1997 BMW M3, oil? [Re: tudorart]
stancyeze Offline
A tech where I work told me to get 15W50 actually, and Motul is a decent race oil, but to each their own.
#3390828 - 06/06/14 03:46 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
tudorart Offline
double post...sorry.
Edited by tudorart (06/06/14 03:47 PM)
#3390834 - 06/06/14 03:58 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
Lolvoguy Offline
Loc: Canada
Why not use diesel? if anything it has a more robust additive pack than other conventional oils.
I run 15w40 in my 88 325is, and it loves it. The PO ran it on M1 15w50.
Save your money OP, unless you actually take advantage of the longer OCI's.
07 Focus ZX4 SES- Wife
88 BMW 325is- Mistress
03 Suzuki SV650S- One night stand
#3390835 - 06/06/14 04:00 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
Rand Offline
Loc: NE,Ohio
most "diesel oil" is actually dual rated. and has a "stronger" additive pack
there is no 10w40 rotella,
there is 15w40, 5w40, 10w30, and 30wt
2015 Forester I-Premium 6MT
#3390843 - 06/06/14 04:07 PM Re: 1997 BMW M3, oil? [Re: Rand]
chrisri Offline
Loc: Fiume,Croatia,EU
Diesel oil in M3?Try Motul 300v 10w40 chrono.
99 FIAT Punto Sporting 16v ( Shell Helix Ultra 5w40 )
06 FIAT Stilo MW 1.9 Multijet (Selenia WR 5w40)
#3390861 - 06/06/14 04:21 PM Re: 1997 BMW M3, oil? [Re: Rand]
Clevy Offline
Loc: Saskatoon canada
Really?
So I must have hallucinated the t-5 10w-40 I saw,and the 0w-40 t-6 I almost bought yesterday doesn't exists.
And the 0w-40 t-5 right beside the t-6 was part of my dream too.
Dude. I suggest looking before posting false info.
Rotella can be found in pretty much every grade made. The only grade rotella I haven't seen are 50 grades,and 5w-30 grades,but I'm not saying they don't exist,just that I haven't personally seen them.
They've got pretty much everything else.
So your incorrect
2006 Charger RT
Miles x 2 per oil filter
#3390867 - 06/06/14 04:28 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Unless you're engine is worn (and an oil pressure test will tell your that), you shouldn't need to run anything heavier than the BMW 5W-30. In fact any 5W-30 should work just fine although they are a bit lower on ZDDP, not that that should be a problem if you don't push your oil change intervals.
So forget the diesel oils and anything heavier than M1 0W-40 without doing an OP test first. If you don't need a heavy oil your engine will run a lot better on something appropriately lighter.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3390874 - 06/06/14 04:35 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
yvon_la Offline
Loc: quebec canada
even big truck are going to lighter oil ,so I doubt the oil thickness in your car will be an issue!just make sure its sn and gf-5
Truck driver
Nissan versa note s 2014 Mobil Delvac 1 LE 5W-30 supertech st-6607(edition 2016) castrol transynd
#3390876 - 06/06/14 04:35 PM Re: 1997 BMW M3, oil? [Re: CATERHAM]
stancyeze Offline
Too light weight, those are more like winter weights for these older BMW's. When these cars came out they were requiring 10W-40 and 20W50 things of that natural, keep in mind these were conventional oils.
#3390877 - 06/06/14 04:36 PM Re: 1997 BMW M3, oil? [Re: Clevy]
stancyeze Offline
Really?
So your incorrect
So should I try out diesel oil on my car? I've always wanted to, my friends have had good luck with it in there high performance cars pushing higher torque and horsepower.
#3390881 - 06/06/14 04:43 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
d00df00d Online   content
Loc: PA
Mobil 1 0w-40 is by FAR the best bang-for-the-buck. It carries the correct approvals for your car (as well as approvals for a lot of really high-performance applications), and can be had for just over $5/qt at Wal Mart any day of the week.
BMW 5w-30 is a good choice, too.
I had great results in my '96 M3 with RLI engine oils. I used the 0w-30, 5w-40 HD, and 15w-40 Low Ash. The 0w-30 was my favorite, but I ended up with the 15w-40 Low Ash to help fight oil consumption and its bad effects.
Motul was underwhelming to me. I tried the old X-Max 5w-30, the old X-Cess 5w-40, and 300V 5w-40. All were exceptionally tough but seemed unremarkable otherwise.
Diesel oils having a "stronger" or "more robust" additive pack is a popular idea, but it's really only true if you compare the average diesel oil to the average passenger car oil. Anything with the right approval for your car (BMW LL-01) will be plenty "strong" and "robust," and it'll have been made for cars like yours in the first place (unlike diesel oils).
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#3390928 - 06/06/14 05:45 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
ddtmoto Offline
Loc: Utah
Just make sure you address the DISA intake variable valve issue before in takes your motor out like the one I had the pay for. Pretty dang costly to put a used motor in a Beemer.....
Mustang GT 5.0 Brembo '11
ram 5.9
TL1000S
GSXR1000
DRZ400E
'09 GTZ1400 Concours
#3390942 - 06/06/14 06:07 PM Re: 1997 BMW M3, oil? [Re: d00df00d]
oliveoil Offline
Loc: snow and sun
Yes......what he said.
#3390963 - 06/06/14 06:39 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
901Memphis Offline
Loc: Northern Kentucky
Mobil 1 0W40 European Formula at Walmart for about $25 per 5 quart jug. The most certified oil per dollar in the US.
2002 Buick Century 125k - Built 4T65e(Maxlife) - M1 0w40 /Fram Ultra XG 3387A
1998 Nissan Altima 335k - 5MT - M1 HM 5w30/Fram Ultra XG7317+MOS+ATP 205
#3390968 - 06/06/14 06:49 PM Re: 1997 BMW M3, oil? [Re: stancyeze]
HosteenJorje Offline
Loc: Columbus,Nebraska
Put that Mobil in and forget about the diesel nonsense.
#3391021 - 06/06/14 08:01 PM Re: 1997 BMW M3, oil? [Re: ddtmoto]
Loc: PA
No such thing in this car.
Also, installing a used engine in this car is not as expensive as you might think.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#3392108 - 06/08/14 11:01 AM Re: 1997 BMW M3, oil? [Re: stancyeze]
dparm Offline
Loc: Chicago, IL
Stancy, I'd use whichever "Euro oil" (5w40/0w40) is on sale at the time of your next change. You have many good choices such as Mobil 1 0w40 and Pennzoil Ultra Euro 5w40, as others have said.
2011 BMW M3 sedan ZCP
#3393137 - 06/09/14 03:28 PM Re: 1997 BMW M3, oil? [Re: d00df00d]
MCompact Offline
Loc: KY
Exactly. My M54 had a DISA issue but it was easily repaired.
I don't know, I'd think that installing an I6 in a BMW motorcycle would be on the expensive side. crackmeup crackmeup
Mine:
2014 M235i
1999 Wrangler Sahara
1995 318ti Club Sport
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
Buy what makes you smile...
#3393153 - 06/09/14 03:47 PM Re: 1997 BMW M3, oil? [Re: MCompact]
Loc: PA
Hah! Good catch.
2011 Mazda RX-8 R3
Castrol GTX 5w-20
#3394729 - 06/11/14 10:40 AM Re: 1997 BMW M3, oil? [Re: d00df00d]
MCompact Offline
Loc: KY
Hah! Good catch.
A bit OT, but how are you liking your R3? I found a 2011 R3 with the LM20 (sticker)package and I am more than a bit tempted...
Mine:
2014 M235i
1996 Speed Triple
Wife's:
2004 X3 2.5i
Son's
2009 328i
#3395064 - 06/11/14 07:19 PM Re: 1997 BMW M3, oil? [Re: MCompact]
Loc: PA
I'll send a PM or make a thread. :]
2011 Mazda RX-8 R3
Castrol GTX 5w-20
Page 1 of 2 1 2 >
