My Harbor Freight 3500 RV generator started sounding smooth around the 25-30 hours time as an example when I summed it up to "Breaking in".Sudden change? sure it's not the ECU "unlocking" after what it thinks was an appropriate break-in time?
But was it "sudden" or was it "gradual"?My Harbor Freight 3500 RV generator started sounding smooth around the 25-30 hours time as an example when I summed it up to "Breaking in".
While directly not on the subject exactly,,, in the early 1970s when building hot rod engines I read the how to hot rod small block Chevy engines and remember the author citing a sae study where the full flow filtered engines lasted much longer that the same engines equipped with bypass only filters. I have see this with industrial engines at work , the full flow filter [same] engines easily lasted double the hours as compared to the bypass only filter engines maintained on the same schedual.I'm not convinced that "break in" particulate is either damaging or not damaging. It's all theory either way. There's no study specific to this topic using good DOE protocol to say one way or another.
I do early oil changes for break in. But that's because I want to start UOAs early, and so I do a few early OCIs to "flush" the system clean, sooner. If I do three OCIs in 5k miles, I can then hope to get a fairly "normal" wear trend understanding at 10k miles. But if I do three OEM OCIs at 10k miles each, then I have to wait until 30k miles to even start my fourth OCI for the UOA (to be taken at 40k miles).
A few early flushes may or may not assure longer engine life, but they certainly does allow one to get the break-in metals out earlier so UOAs won't be skewed early on.
NOTE:
my 2023 Lexus ES350 had a lot of particulate visible in the filter upon its first oil/filter change at 1k miles.
my 2023 Mazda MX-5 had no particulate in the filter visible at all; spotless pleats after the first 1k miles.
Does that indicate that either will have a long life, or a short one? I doubt it.
It was more of a quick change b/c it hadn't sounded that good anytime before when I'd fire it up to run. It could've happened over the course of a few hours the last time it ran? I heard a certain sound up until that point & that's when I noticed the change in tune.But was it "sudden" or was it "gradual"?
I could buy into this, a gradual shift over a few hours, due to break-in, on OPE. Not saying that all OPE is made in sweatshops with a dirt floor... just that, I would not be shocked if it wasn't quite the same clean room enviroment that I like to think all auto engines (or engines in general) are assembled in.It was more of a quick change b/c it hadn't sounded that good anytime before when I'd fire it up to run. It could've happened over the course of a few hours the last time it ran? I heard a certain sound up until that point & that's when I noticed the change in tune.
The longer they talk the more money they make.I had to bail after the second round of, "Heck, I don't know.....".
When will these people realize that they are failing miserably at creating TV shows and imitating public speakers?
Gimme a 2 minute video with the point you want to make.
Flame suit on.
Have broken in 3 new vehicles in the last five years. All had oil changes at around 2K, 6K and 10K. All were treated to several Italian tuneup once up to temp. All use no oil to speak of. Almost any trip I take, results in one or two runs to 80-90% of redline once of to temp.
Thanks for sharing.Here are some charts of real-time break-in wear data from a radioactive tracer study. The engine is a V6 from a 2015 Dodge Charger that is broken in on a dyno with a variable driving cycle. The oil and filter were not changed for the entire 144 hour test.
The wear rate is quite high for the first 10 hours or so, then it settles to a very low level, despite all the wear metal in the oil. If the oil were changed after 10 hours, maybe the wear rate would be even lower afterwards, but it's already low enough that there's not much to be gained.
Most of the wear metal in the oil that is large enough to cause wear will quickly get either trapped in the oil filter, or pulverized by the engine to a size that is unable to cause further wear. Draining out this sub-micron metal is probably not very beneficial unless the contamination level is really high. What would be more beneficial is immediately replacing the OEM oil filter with one that is more efficient, so that the larger wear metal particles can be captured during the break-in process, before they cause additional wear.
View attachment 193069View attachment 193070
Break in is a real thing. After 4,500 miles my new car engine took a flying leap in power. I can easily tell by the long very steep hill I have to climb coming home. I have picked up a 6mph increase in performance up the hill. What is that a result of? Probably tight engine friction. As metal wear friction is reduced It winds up in the oil as metal particles. Change it out.
