AFAIK, VW/Audi never admitted to anything and the filter PN changed while it grew bigger. More media to catch the sludge. Larger oil capacity to make up for the small sump should hopefully reduce oil temperatures. And, if the filter is in the line of airflow, the larger surface area can also cool your oil.... Multiple benefits add up and the engine hopefully doesn't self destruct.
Also, in some of my old Fords, the big working HD trucks took the 2x-sized filter, the commoner trucks took the regular filter, and some with suspension or 4wd clearance issues took the 1/2-sized filter.
Concerning racing, why even use a stock tin-can filter? I would think that they would want to use a CM/Canton, Trasko, Trufilter, Scotts, GoPurePower, or other thicker walled aluminum housing with replaceable filter element. I'd also want to inspect the media easily with a racing engine so a cartridge design would be a must too.
Weren't some Honda filters sourced from the makers of Fram? Enough said!!
Here is a thought for you. We're going to overpay some engineers to build an extremely high RPM, high HP, race engine and still use a stock oil filter. I bet their fluctuations are caused by the bypass opening and closing. That would be an interesting harmonic to log. Add that harmonic to the oil pump's slip harmonic. Oil pump slip varying with load(bypass opening and closing) and you have some serious under-engineering. And, wonder how the media moves around at the high-rpm flow rates. Ripple ripple ripple effect! I'm surprised the engine didn't shake itself to death.
And Honda's engineering's genius fix, a hose clamp around the housing. Are you kidding me? Oh wait, same guys that came up with the transmission oil-jet mod.
