- Joined
- Oct 21, 2021
- Messages
- 7
I have been doing some research on the various Rotella 15w40 oils and have a few question hopefully you all can help with. I have been using the T4 claimed "synthetic blend" for some time and considering the benefits of switching to T5 or T6. Was wondering if anyone has made this change and seen any benefits in switching to the synthetic blend or full synthetic products? The only issues I have being an OTR driver is there seems to be a huge price difference in getting the T5 and T6 oil changes compared to T4. It seems to average about $175-$225 more for the higher grade synthetics compared to T4. Also there have been times I've been in need of an oil change and out in some remote area that doesn't have the T5 or T6 at all. Sometimes time and location restraints do factor in when needing an oil change on the road and T4 seems to be the most readily available between the three products. I have actually been mixing a synthetic additive called FR3 from Hot Shot Secrets with the T4 for the past few oil changes. The FR3 costs an extra $50 per oil change requiring 64oz in a semi truck. My current approach has been to create my own improved synthetic blend of the T4 and stick to the the T4 since the cost is significantly lower and oil is consistently available. Wondering if it would be efficient to continue my method or switching to T5 or T6 and cutting out the FR3 additive? Also any thoughts on the risks of switching between all three oils based on shop availability? I have heard risks of switching back to a conventional after using synthetic but have never done this and can't say I know much about the specific subject. Any thoughts and feedback on anything discussed here would be greatly appreciated!
Here are links to the FR3 product if you would like to check it out:
FR3 Oil Friction Reducer Additive | Hot Shot's Secret
Increase fuel economy, reduce oil temperature, engine wear and more with Hot Shot's FR3 friction reducer oil additive. It has a 5 year shelf life.
www.hotshotsecret.com
