I have a Yukon XL 2500, 6.0L with 42 K miles. I pull a 5500 lb RV Camper. I'm want to do my first transmission fluid / filter change. Is Lucas considered a good conditioner compatible with Dexron VI for my "hard working" transmission.
Originally Posted By: spasm3
I tend to keep anything with the lucas name as far away from my cars/truck as possible.
+1 im not a fan.. I also agree that good service intervals on your tranny are all you need. If you get to pulling heavy duty, a big cooler would serve you better than any fluid additive. 30,000 is a very safe bet on tranny OCI's
I'm not a Lucas fan either - but the Lucas thick oil treatment did worked when I poured it on my chainsaw bar once when I ran out of bar oil.
And an empty Lucas fuel treatment bottle works well for putting other (non lucas) fluids in the bottle to add to the tank.
Yes it does have the complete tow package. I thank you all for advice. It's amazing how one like myself can become deceived about what products can do.
And the gears & crank handles thing is fun to play with.
BTW - while you can use anything in a pinch for bar & chain oil (well maybe not Crisco) but the normal bar & chain oil has a tacky component so it does not fly off the chain so easily.
Ask yourself, what are you trying to do to the fluid to condition it? What is in Lucas that will raise performance of a fully formulated DexronVI? I can tell you, absolutlety nothing.
DexronVI is a good fluid and no additives are needed.
Change your oil every 30 K miles if you are pulling anything.
