New to me 2018 Grand Caravan 3.6 weight questions.
by racinjason. 07/18/19 07:38 AM
Help With 6L80E Fluid & Pan Replacement
by Sierra048. 07/18/19 06:39 AM
98 Expedition heating system flow diagram
by Fitz98. 07/18/19 12:39 AM
How did I become the constable?
by Chris142. 07/17/19 11:05 PM
Changed oil, Ravenol FullSynth Turbo VST 5W-40
by NotEnoughSpeed. 07/17/19 08:30 PM
Blending TCW3 in diesel
by 32319. 07/17/19 08:27 PM
Leaking Batteries
by ecotourist. 07/17/19 08:22 PM
Shake down tow complete!
by ls1mike. 07/17/19 08:22 PM
Looking for cheap int'l air tix
by daves66nova. 07/17/19 08:05 PM
Not *new* per se, but $3.98 for 5 quarts of M1
by mrdctaylor. 07/17/19 07:45 PM
Winter tires for 2019 Ram
by NissanHauler. 07/17/19 06:16 PM
Is the car hobby/enthusiast a dying breed?
by Redright9. 07/17/19 05:48 PM
Mobil One design change M1C-154A
by piesled. 07/17/19 05:26 PM
crazy granny gear spotted
by Number_35. 07/17/19 04:32 PM
Grease gun suggestions
by rideon. 07/17/19 04:16 PM
17 Imprezza 2.0
by JHogan. 07/17/19 03:42 PM
Grousebeater, RoyD, clonis, golddots, Baronmoye
68698 Registered Users
102 registered members (4WD, 1978elcamino, 53' Stude, AandPDan, 64bawagon, 2009Edge, 9 invisible), 1,693 guests, and 20 spiders.
Topics292,013
Posts5,015,324
Members68,698
Most Online2,967
Mar 10th, 2019
Leaving Amsoil Ea15k filter for 2 oil changes? #5136492
06/17/19 11:15 AM
06/17/19 11:15 AM
SE MI
metroplex Offline OP
SE MI
I've searched on BITOG and it seems like there are a few who are using their Amsoil filters for more than 1 oil change. I'd like to use an Ea15K for another oil change to reach the 15,000 mile mark with a single filter. Is this considered safe? I know there are those who will argue that the filter is cheap enough to just change each time, but do we REALLY need to change the oil filter each time? It seems if the media is strong enough and nothing breaks/wears down, we should be able to reduce waste and keep using the filters?
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136511
06/17/19 11:38 AM
06/17/19 11:38 AM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
If your engine is clean inside - - I don't see why not. That is likely a very robustly made filter. (Donaldson?)
Back in the mid-1990's, I ran a Motorcraft FL-1A on a 400M 2bbl V8 in a Ford F250 for 30,000 miles (3x OCI's), and when I cut it apart it looked perfectly fine.
No "failures" of any kind, and just some carbon(?) chunks between the pleats that were just big enough to make it through the oil pump screen.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136631
06/17/19 01:45 PM
06/17/19 01:45 PM
Houston, TX
czbrian Offline
czbrian  Offline
Houston, TX
You can leave the filter on for two intervals. I do the same but with Fram Ultras.
2006 Honda Pilot
1998 Chevrolet C1500
1995 Chevrolet C1500
2018 Mitsubishi Outlander PHEV
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5136901
06/17/19 06:16 PM
06/17/19 06:16 PM
Western S.C.
CR94 Offline
CR94  Offline
Western S.C.
There's no reason not to leave it at least two changes, if (and only if) the engine has a history (like Linctex's and mine) of leaving very little junk in previous filters.
2011 Toyota Prius now at 101K
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5137185
06/18/19 02:43 AM
06/18/19 02:43 AM
Dallas TX
MetalSlug Offline
MetalSlug  Offline
Dallas TX
I did use 1 filter for 2x oil change before . But over the years I like new filter every oil change . Don’t matter what filter it’s . I like feeling that I have fresh oil filter with fresh oils .
Like some one here saying “ it like you take a shower but rewear the old underwater LOL
03 SVT COBRA 10th anniversary Whipple 600whp Halvoline FS 5w30 Napa Platinum PFL 41516
01 Corvette ZO6 stock M1 5w30 / M1-107A
2016 NISSAN TITAN dealer OC daily drive
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5137368
06/18/19 09:52 AM
06/18/19 09:52 AM
Fort Worth
Pinoak Offline
Pinoak  Offline
Fort Worth
It's rated for 15k miles so under normal circumstances it should be good for at least 15k. Myself personally I'd leave it for 20k or more if under normal ideal conditions. I'd assume since you take the time to wonder about questions like your asking that you arent one to let your vehicles go unmaintained.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5138037
06/19/19 12:21 AM
06/19/19 12:21 AM
FL
Deontologist Offline
FL
Wouldn't leaving the filter in place be better for the first start after an oil change? Shouldn't the oil build pressure faster? I mean you could prefill the filter, but on many vehicles the oil filter is sideways and not really readily prefillable.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: Deontologist] #5138067
06/19/19 02:45 AM
06/19/19 02:45 AM
Dallas TX
MetalSlug Offline
MetalSlug  Offline
Dallas TX
Million vehicles been install dry oil filter every day , and they still fine . Also on many how to videos from all brand oil filter show how to do an oil change , for example is fram , they don’t fill oil on the filter before install . I think first 2-3 second is fine.!
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: Deontologist] #5138069
06/19/19 03:04 AM
06/19/19 03:04 AM
Texas
4WD Online confused
4WD  Online Confused
Texas
Well, for that one start among many. With my L83’s it’s 7 quarts when I leave the filter on and 8 quarts when I change it …
Same with these vertical filters regardless of black or orange or purple ADV …
So, have an RP on one that’s going 2 OCI’s and an AC Delco that’s not …
Both engines probably wear at the same rate …
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5138521
06/19/19 03:28 PM
06/19/19 03:28 PM
Wilmington, NC
harry j Offline
harry j  Offline
Wilmington, NC
I left an Amsoil eao20 a long time ago for 3 OCI's with no problems. The filter is now known as the ea15k20.
As an experiment, the last OCI was with this Ea15k20 filter and I had the best ISO oil cleanliness code and
particle counts in a long time. I normally use the Amsoil eao35 filter that is unfortunately no longer made.
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: MetalSlug] #5139739
06/20/19 11:10 PM
06/20/19 11:10 PM
Cajun Country, La.
BlueOvalFitter Offline
Cajun Country, La.
+1
"One Filter, One OCI!"
2007 F150, 4.2 V6
Havoline HM 5W20, MC FL-400S
"One Box, One OCI!"
Re: Leaving Amsoil Ea15k filter for 2 oil changes? [Re: metroplex] #5141057
06/22/19 04:18 PM
06/22/19 04:18 PM
Wilmington, NC
harry j Offline
harry j  Offline
Wilmington, NC
I think if your oil filter is vertical, I can't see any harm in filling the filter before installing. Seems like the thing to do.
