Faulty clutch master cylinder 17” Honda Civic
by parshisa - 02/22/20 07:33 PM
Ford drain plugs
by buck91 - 02/22/20 07:09 PM
What's the greatest amount of miles you've heard of someone
by Speak2Mountain - 02/22/20 05:53 PM
Oil Jug - Leaking
by MasterSolenoid - 02/22/20 05:40 PM
Which one
by tiger862 - 02/22/20 05:05 PM
HM from the start?
by AJB0009 - 02/22/20 04:00 PM
Fram XG3600 instead of XG3614
by BTW574 - 02/22/20 03:57 PM
Unbranded Hydraulic Fluid Filters
by shibby6600 - 02/22/20 03:53 PM
Homemade pizza
by 53' Stude - 02/22/20 03:07 PM
New Shoes For The Tacoma!
by Delta - 02/22/20 02:52 PM
Giti tires - newish large brand.
by pezzy669 - 02/22/20 02:51 PM
New pennzoil oils
by Spitter - 02/22/20 02:26 PM
Breaking in the new clutch. Backwards.
by Chris142 - 02/22/20 02:18 PM
Toyota 0W20 $2.95 + shipping YMMV
by Q451990 - 02/22/20 01:34 PM
Toyota Catalytic Converter (B2)
by MaximaGuy - 02/22/20 01:31 PM
The Camry lives!
by 53' Stude - 02/22/20 01:01 PM
Don't Try This at Home
by MrMoody - 02/22/20 12:11 PM
Fake Online Parts
by Gebo - 02/22/20 11:04 AM
Valvoline Premium Blue Restore questions
by Hubbs1982 - 02/22/20 09:54 AM
jb5150, ZProfessor, ArgleBargle, Dannycal, ManishHonda
70780 Registered Users
116 registered members (55hambone, ABomb369, ajchien, AdditiveOCD, Ag76, ammolab, 10 invisible), 1,748 guests, and 19 spiders.
Topics301,801
Posts5,202,992
Members70,780
Page 68 of 86 1 67 68 69 86
Re: post your latest transmission lubricant change. [Re: ledslinger] #4889513 10/06/18 06:55 PM
J
JeffKeryk Offline
J
2006 Acura TSX, 180K miles, 26K trans service OCI
Out: 3 qts Honda DW-1
In: 3 qts Idmitsu Type H
This is good stuff. Car has steady diet of Honda AT fluids.
This Idemitsu fluid pulls better.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4890900 10/08/18 10:45 AM
H
hallstevenson Offline
H
Replaced the rear differential fluid on my '08 G35X with 115k miles. My sister owned this car before me and I have all of the service records up to ~65k miles as they took it to the Infiniti dealer for all work up until then. After that, they took it to an independent shop for most work (some still done at Infiniti) but didn't keep all of the records. My BIL doesn't recall them having the differential fluid changed....
Anyway, when it came out, it looked dark but I later poured a couple hundred mL into a jar and it actually looks like ATF since it's read in color. It's thicker though, for sure, and smells more like heavy oil or grease. I put in Lucas Heavy Duty 80W-90 (GL5) which was amber color (much like motor oil).
Anyway, is that typical for gear oil to look red like ATF ?
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891354 10/08/18 06:32 PM
E
EricBeau Offline
E
2010 Honda Odyssey in signature
108,436 miles on vehicle
8,893 miles on fluid, in service since 10/06/2017.
Out: Approximately 3.3 qts Valvoline MaxLife ATF
In: Same
I like to do a simple drain and fill annually. Makes me feel warm and fuzzy and it’s cheap ($18.00) and easy (same amount of work as an oil change).
2016 Honda Civic LX CVT
Mobil 1 AFE 0W-20 and Honda A02 filter
2010 Honda Odyssey LX
Mobil 1 High Mileage 0W-20 and Honda A02 filter
Honda Service Advisor
Re: post your latest transmission lubricant change. [Re: ledslinger] #4891940 10/09/18 12:49 PM
L
lucky3 Offline
L
Just changed the trans fluid and filter in my 2013 silverado. Just did a dump and fill. Used acdelco dexron 6. Had 104000miles. I bought it with 96000.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4892053 10/09/18 03:55 PM
H
harbor Offline
H
Changed out the Spider tranny & diff fluid with Motorcraft XT-M5-QS (the Miata guys rave about this) and M1 in the diff. Noticeable improvement!
2019 Dodge Challenger AWD GT
2018 Jeep Grand Cherokee
2018 Fiat 124 Spider
2017 Jeep Renegade
Re: post your latest transmission lubricant change. [Re: ledslinger] #4893483 10/10/18 10:07 PM
J
JeffKeryk Offline
J
2005 Honda Civic LX 55K miles
Out: less than 3 quarts factory fill.
In: 1 quart DW-1 plus almost 2 quarts MaxLife
Original fluid was a little low and brown; not too bad.
She shifts better; no clunk.
Will do it again soon with Idemitsu Type H Plus.
2018 Lexus RX450h
2006 Acura TSX
Re: post your latest transmission lubricant change. [Re: ledslinger] #4894641 10/12/18 10:36 AM
T
tig1 Offline
T
Since M1 does not have an ATF with the Mercon LV rating I decided to do the next best thing and used Valvoline Max Life LV for my usual 30K ATF change.
Out: MC Mercon LV
In: 3.5 QTS. of Valvo Max Life LV.
2007 Ford Fusion 253,000 miles
M1 5-20HM
2017 Ford Fusion 86K
M1 0-20EP
M1 ATF and M1 LV HP ATF
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4895065 10/12/18 07:14 PM
T
tig1 Offline
T
Changed out the ATF in my grandsons 2012 Ford Fusion.
Out: Unknown.
In: Valvoline Maxlife LV.
M1 5-20HM
M1 0-20EP
M1 10-30 in all OPE
MC filters
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898903 10/17/18 05:16 PM
K
Kira Offline
K
Neighbor's 2010 Honda Accord @ 100,240 mi.
3 qt. OUT
3 qt. IN
Honda Genuine DW-1 both
Re: post your latest transmission lubricant change. [Re: ledslinger] #4898931 10/17/18 05:46 PM
R
Red91 Offline
R
Rear diff on 00 Econoline e150, 3.55 LSD
Out: Mobil 1 75/90, 75/140, Napa 80/90(bad axle seal and bearing)
In: Mobil 1 75/140
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4902464 10/21/18 08:30 PM
L
ledslinger Offline OP
L
1999 Honda Accord, 2.3 4 cyl, 5 speed manual transimission. Out-Honda MTF, in Elf/Total Racing HTX 735 75w-90. 2 quarts. 220K miles on unit.
Re: post your latest transmission lubricant change. [Re: ledslinger] #4903097 10/22/18 01:58 PM
M
mrdctaylor Offline
M
2012 Toyota Highlander. 3rd ATF change. Almost 100K miles on vehicle.
Out: Toyota WS (~4.75 quarts)
In: Toyota WS (~4.75 quarts)
#boring
02 Tacoma 3.4L, 233K, Hav ProDS 10W30 (me)
12 Highlander 3.5L, 115K, Napa Syn 0W20 (wife)
17 Escape 2.0L, 53K, P66 Shield Choice SynBlend 5W30 (son)
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905204 10/24/18 06:10 PM
R
Red91 Offline
R
01 grand Cherokee 2wd
3.55 Dana open diff
Out: unknown
In: Napa 80/90
05 Chevy Impala
3.4 V6
Pit crew QS 10/30
Re: post your latest transmission lubricant change. [Re: ledslinger] #4905528 10/25/18 08:32 AM
A
AzFireGuy79 Offline
A
2008 4runner Limited V8 @ 72,000 miles
Out: 11 quarts factory fill WS ATF
In: 12 quarts (cooler line exchange) WS ATF
Next change will be Ravenol Synthetic PAO T-WS
Re: post your latest transmission lubricant change. [Re: ledslinger] #4906034 10/25/18 06:52 PM
K
khittner Offline
K
‘02 Camry w/273K miles. Pan drop and filter change at 30K OCI. Out 5qts. of Maxlife; in a 5qts. of same w/Beck Arnley filter. No crud in either the pan or on magnets. Smooth shifting before and after.
