Anti-Counterfeiting packaging
by sloinker. 01/17/19 09:13 PM
Heavy Snow Predicted for Northeast Sat/Sun
by Donald. 01/17/19 08:34 PM
Pennzoil Ultra Plat 5w30 1.4L T Chevy Cruze 10k
by SubieBlue. 01/17/19 08:03 PM
Coated rotors
by supton. 01/17/19 07:51 PM
Good samaritan
by JLTD. 01/17/19 07:15 PM
Doing suspension work. Need alignment?
by HawkeyeScott. 01/17/19 05:45 PM
100mg CBD Cannabis Gel
by Al. 01/17/19 05:36 PM
Electric Car "Green Test"
by redbone3. 01/17/19 05:06 PM
Want to try a uoa
by Dylan1303. 01/17/19 04:56 PM
Happy Birthday, Betty White!
by eljefino. 01/17/19 04:20 PM
Fram Ultra for Ecoboost 2.7
by Purpfox. 01/17/19 04:10 PM
Idle Speed / 1998 Olds 88
by Mark72. 01/17/19 03:28 PM
Heat blanket for your oil filter!
by MrWideTires. 01/17/19 03:24 PM
Proper oil viscosities.
by Bullwinkle007. 01/17/19 03:20 PM
44$ for 5 gals of home heating oil treatment!
by Audios. 01/17/19 03:05 PM
Good job Hyundai!!!
by Andy636. 01/17/19 02:43 PM
PP 0W-20 vs PP HM 0W-20 - Difference in VI
by The Critic. 01/17/19 02:34 PM
Dickerson888, Frisky, polarisman340, jfradella, Bigyetti83
66964 Registered Users
119 registered members (209paulc, 2015_PSD, 40w8, 4WD, 2009Edge, 10 invisible), 1,563 guests, and 40 spiders.
Topics296,753
Posts4,958,249
Members66,964
Most Online2,577
Jan 14th, 2019
Mobil 0w 40 FS vs 0w 40 ESP #4722647
04/10/18 10:29 AM
04/10/18 10:29 AM
PENNSYLVANIA
Crobinson16 Offline OP
PENNSYLVANIA
What are the differences between the FS and ESP 0W 40 Mobil oils. Is one better for a GDI over the other. TBN, noack? The ESP came out for the new Corvette spec, but I wasn't sure what the difference was to warrant a different 0w 40 from what they already have. I have a 6.2 GDI motor in my new 2018 Silverado which is basically the same motor with different cam , intake and other things. I would think a truck motor would be subject to harsher environment and running conditions just from the weight difference between the two vehicles let alone if any towing is done with the truck. I drained the factory fill 0 20 after the first 800 miles and have been running 5 30 Mobil EP. Seeing the new spec 0 40 for the Corvette has me wanting to use that during next oil change. Thoughts?
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4722707
04/10/18 11:26 AM
04/10/18 11:26 AM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
First of all, the new 0w40 ESP isn't available in retail outlets yet, and isn't supposed to arrive until about the end of the summer at the soonest (and possibly later considering the supply problems they've been having getting this oil into GM dealer so far)
This new oil is dexos2 certified, so it has lower sulphated ash and phosphorus compared to the FS formula. It will also have a lot less calcium in it too I predict. Based on those things, it should be a better oil for direct injected engines.
Because I can't get my hands on this new 0w40, and I'm impatient, I decided to go with the 5w30 version of M1 ESP for my next oil change, and I might continue using it for a while. On paper I think the 5w30 ESP specs look better than the 0w40 ESP specs (and it should retain it's viscosity better due to less VII)
2018 Corvette, 9k, M1 ESP Formula 5w30 & NAPA Gold
2006 Civic EX Coupe, 148k, PUP 5w20 & Fram Ultra
2010 BMW 328i X-Drive,111k, GC 0w40 & Fram Ultra
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4722718
04/10/18 11:35 AM
04/10/18 11:35 AM
PENNSYLVANIA
PENNSYLVANIA
What do you think keeps it from getting the Dex1Gen2 approval? Isn't that what the original spec was, just different vistosity?
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4722724
04/10/18 11:37 AM
04/10/18 11:37 AM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
The new 0w40 can't be dexos1 approved because it's HTHS is over 3.5. That's part of the reason they made the switch, GM wants a thicker oil that Corvette owners can use for both street and track. (although I think they might also be wanting a thicker oil in there to help counter the effects of fuel dilution)
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4722853
04/10/18 02:33 PM
04/10/18 02:33 PM
Bucks, PA
zfasts03 Offline
zfasts03  Offline
Bucks, PA
I understand your rational comparing to the vette gen 5 small block, but wasn't a bulletin issued that mentioned that 0w-20 should only be used in the L83?
With an dual output oil pump, 8 qt. sump and an oil cooler, not sure it would be a good idea to go that heavy.
Mine seems quiet, smooth with M1 0w-20 AFE.
I may switch to Amsoil sig ser. 0w-20 when I run out of M1.
03 Corvette Z06
-Amsoil 5w-30 SS
07 Honda Accord 2.4L
-Amsoil 5w-20 SS
16 Suburban 5.3L
-M1 0w-20, XG10575
18 4Runner TRD Off Road
- Amsoil 0w-30 SS, TRD filter
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4722904
04/10/18 03:43 PM
04/10/18 03:43 PM
Texas
4WD Online confused
4WD  Online Confused
Texas
Iím a bit puzzled by the 0w20 in my new 5.3L Ö but sticking with that for the near term Ö
Running M1 EP assuming the DI might cut it less than AFE Ö donít know but $4 more?
Of course 5w30 has put many millions on 5.3Lís Ö
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Patman] #4723917
04/11/18 04:48 PM
04/11/18 04:48 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
IMO, 5W30 ESP is much better choice. This new M1 GTL based oils are IMO mediocre compared to VISOM based ones.
15' Toyota Sienna AWD (Mobil1 0W20 EP+ 2qt of M1 0W40 + FRAM Ultra).
11' VW Tiguan 2.0T (Castrol 0W40+MANN filter)
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4723921
04/11/18 04:52 PM
04/11/18 04:52 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
You also asked in previous topic which is better for GDI.
Depends. Is there fuel dilution issue in Vette? If there is, 0W40 FS should be better, although it has really, really high sulfated ash levels.
Also, does engine in Vette comes with port and direct injection? If it does, then lower SAPS oil is not necessarily better.
IMO, I would use in Vette Castrol 0W40.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4723940
04/11/18 05:12 PM
04/11/18 05:12 PM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
I did have 2% fuel in my first UOA with my new Corvette but it's also possible that was because the engine was so new and rings weren't fully seated and the engine probably went through a few start and stop cycles without fully warming it up while it was being moved around the assembly plant and loaded onto the car carrier and stuff. My second UOA will be more telling as to whether or not it is an issue, at least in my particular case. Mine only has direct injection, but the new LT5 engine that goes in the ZR1 has both port and direct injection. I suspect that technology is going to trickle down to all of the engines when they introduce the next generation Corvette in a couple more years.
I'm going to stick with either 5w30 ESP or 0w40 ESP during my warranty period, but once that's over I may consider using Castrol 0w40 (especially if it proves itself to hold it's viscosity well in my wife's BMW) But I'm not really worried about using a low SAPS oil considering my OCIs won't be that long (maybe 6-8k) And they are going to be lowering the sulfur levels in Canadian gasoline over the next few years too.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Patman] #4723957
04/11/18 05:42 PM
04/11/18 05:42 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
6-8K in GDI that has 2% fuel dilution is long.
I used M1 5W30 ESP in Tiguan and did UOA at 3k. There was no traceable fuel dilution, but TBN was at 1.9 after 3k.
I would do UOA at 3k with 5W30 ESP and see how TBN holds. Also, 5W30 ESP tends to have pretty high TAN (probably due to some ester in base.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4724011
04/11/18 06:44 PM
04/11/18 06:44 PM
Regina, Saskatchewan, Canada
Garak Offline
Garak  Offline
In addition to what was already posted about that, one cannot be dexos1 and dexos2 at the same time.
Plain, simple Garak.
2008 Infiniti G37 - Shell ROTELLA T6 Multi-Vehicle 5w-30, NAPA Gold 7356
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: edyvw] #4724073
04/11/18 07:37 PM
04/11/18 07:37 PM
Oakville, Ontario
Patman Offline
Patman  Offline
Oakville, Ontario
I don't think I'm going to see 2% fuel on a regular basis, I explained above as to why I think it was so high on the first interval. But I am also not going to go straight to those 6-8k intervals without doing some lower mileage UOAs first. For example, I only plan on going 2k on my current fill of M1 5w30 and then I can do a UOA and check the fuel dilution. I think it's going to be almost nil as the idle oil pressure has not changed so far this interval and I have 1300 miles on the oil.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Patman] #4724253
04/11/18 11:47 PM
04/11/18 11:47 PM
Colorado Springs
edyvw Offline
edyvw  Offline
Colorado Springs
Yeah, I would do that. Yes, I read your take on dilution, makes sense.
I am not sure why M1 cannot get higher HTHS out of GTL.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: edyvw] #4724419
04/12/18 07:01 AM
04/12/18 07:01 AM
PENNSYLVANIA
PENNSYLVANIA
Fuel dilution can be a problem , and the current Vette motor or the 6.2 in any platform of the new gm EcoTec is strictly a direct injection. Though I'm sure pre and post port injection will be the next thing coming, hopefully.
Re: Mobil 0w 40 FS vs 0w 40 ESP [Re: Crobinson16] #4822824
07/25/18 11:56 AM
07/25/18 11:56 AM
PENNSYLVANIA
PENNSYLVANIA
I was posting questions in another thread so I figured I'd tag on here sense the title is more appropriate.
In regards to GM's new 6.2l EcoTec3
I'm still trying to understand why the current version Mobil 0 40 fs isn't favored by gm for use in the Corvette. I realized it's a dexos license thing. But really, what is bad, or missing in the fs version that the esp 0 40 has or doesn't have. I'm still new so I don't have a deep understanding of the oil world
So basically the 0w 40 esp is a low saps? And of the 0w40 isn't, so does that mean it bad for just the cats and emmsion system, or does that play into the gdi valve coaking or the sulfer content in us gas. how does the 5w30 esp have a higher hths over the 0w40 esp . Why wouldn't they just is the 5w30 esp. or is there other difference between the two. I was wanting to use the mobile 0w40 fs because it's a pretty good oil from what I can tell and it's available most anywhere for a good price.
