Rotella 10W40
by jakewells
10 minutes 35 seconds ago
Extend WiFi Range at the Laptop?
by clarkflower
13 minutes 50 seconds ago
Silicone containing waxes
by mjoekingz28
Today at 09:44 AM
Matrix totaled
by circuitsmith
Today at 08:32 AM
Door rust problems
by Dave Sherman
Today at 07:51 AM
2016 Honda Civic problems
by dbias
Today at 07:39 AM
Royal purple 75-140 in a subaru rear
by 91camarosRS
Today at 07:32 AM
OCI. With short trips. Nissan 4 liter
by Gawardawg
Today at 06:52 AM
Approach Watching on the Beach @ St Maarten ...
by LoneRanger
Today at 06:41 AM
Honda Accord Needs Shocks; Front, Back, or Both?
by tc1446
Today at 05:50 AM
How much oil does your oil filter hold?
by Snagglefoot
Today at 05:44 AM
better day
by mx5miata
Today at 05:26 AM
BRAVO to Officer Wheeles......
by Sayjac
Today at 05:17 AM
People Watching ....Airport style.
by ZZman
Today at 04:24 AM
Subaru's at play...
by OneEyeJack
Today at 03:50 AM
Treating a 2003 Jetta
by llmercll
Today at 01:41 AM
Brakes not working - brake pedal sinks
by tookien
Today at 12:42 AM
Dave thinks I can make it 12--15k
by Marco620
Today at 12:26 AM
'05 Impala front wheel "squeal". Cost !
by Lee4212
Today at 12:16 AM
One Dollar Per Gallon?
by Y_K
Yesterday at 11:53 PM
JustaDude, 3horseman, Firedog45, WtsTacoma01, Orion62
65265 Registered Users
92 registered (2strokeNorthstar, Andy636, ArrestMeRedZ, 853okg, 2015_PSD, 9 invisible), 1609 Guests and 40 Spiders online.
65265 Members
67 Forums
285589 Topics
Page 1 of 4 1 2 3 4 >
#4662408 - 02/10/18 11:32 PM Purolator failure?
gtmaster303 Offline
Loc: NJ, USA
Maybe y'all can help me figure out if this is good or bad
Attached are pics of Purolator filter after just under 11k miles from my 2010 Caynne V6.
Car currently has 68k miles on it
Filter can out looking very compromised and distorted.
Car is from the northeast, lots of cold starts and short trips. Used Mobil 1 10w30 for about 1.5 years
2012 BMW 528i xDrive
2010 Porsche Cayenne 3.6
#4662409 - 02/10/18 11:34 PM Re: Purolator failure? [Re: gtmaster303]
Reddy45 Offline
Loc: USA
Not good! I'd run it for less miles or use a Fram Ultra (or similar) instead.
#4662411 - 02/10/18 11:37 PM Re: Purolator failure? [Re: Reddy45]
gtmaster303 Offline
Loc: NJ, USA
Care to elaborate why not good?
I'd like some additional details about what went wrong here
#4662413 - 02/10/18 11:39 PM Re: Purolator failure? [Re: gtmaster303]
Nyogtha Offline
Loc: San Antonio, TX
A number of Fram Ultra cartridge filters have been shown to be problematic.
Perhaps consider a Wix as an alternative to test?
"No matter how paranoid you are you're not paranoid enough. Tell the truth. Reach as many people as you can with it. That's your weapon." - Susanne Modeski, aka "Holly" to The Lone Gunmen
#4662417 - 02/10/18 11:55 PM Re: Purolator failure? [Re: gtmaster303]
rooflessVW Offline
Loc: North Carolina
Filter looks put through the wringer.
Start by using an appropriate oil. Mobil 10W-30 doesn't meet the specs for your vehicle and you've likely been beating it into Oblivion with your extended drains and usage pattern.
You need a Porsche A40-approved oil; ACEA A3/B4 at a minimum. Only use Mann, Mahle, or Hengst filters.
I would also look into replacing your filter bypass valve.
"Zed's dead baby, Zed's dead."
#4662420 - 02/11/18 12:01 AM Re: Purolator failure? [Re: gtmaster303]
dishdude Offline
Loc: Phoenix
crzy Did you run over it before you took the pictures?
2018 Challenger SRT
#4662421 - 02/11/18 12:07 AM Re: Purolator failure? [Re: rooflessVW]
bbhero Offline
Loc: Virginia
RooflessVW is exactly right about this... Don't go cheap on oil and oil filter for that make and model vehicle. Get the right oil and oil filter for it.
Nissan Altima 3.5 Coupe Valvoline Advanced Full Synthetic 5w30 Federated Auto 4612ex
"Treat your family like your friends and treat your friends like your family."
#4662423 - 02/11/18 12:16 AM Re: Purolator failure? [Re: gtmaster303]
MrQuackers Offline
Loc: Oregon
model, #
Master the 1000 yard stare
coffeeMobil 1 USA
#4662427 - 02/11/18 12:25 AM Re: Purolator failure? [Re: gtmaster303]
Reddy45 Offline
Loc: USA
The way the filter looks to be 'crushed' inwards seems like an indication the media lost its rigidity or there was a pressure issue and the filter couldn't go into bypass mode. Just my novice guess though as there are some experts here who can read the condition better.
I know the cardboard/fiber end caps are not a problem, but I'd personally feel more comfortable with a 10K OCI if my filter had metal end caps.
*Edit - I guess this is a cartridge filter so the metal end caps aren't applicable -- disregard that point.
#4662429 - 02/11/18 12:30 AM Re: Purolator failure? [Re: Reddy45]
ZeeOSix Offline
Loc: PNW
Yep, looks like too much delta-p going on. The cold weather start-ups with thicker than specified oil doesn't help. Internal bypass valve might not be working correctly either.
#4662436 - 02/11/18 12:56 AM Re: Purolator failure? [Re: gtmaster303]
das_peikko Offline
Let me see if I have all the details straight:
1. You drive a 2010 Porsche Caynne
2. You were using a Purolator oil filter that appears to be catastrophically deformed
3. You normally run an OCI of 11,000 miles
4. Drained oil appears to completely black or near black
Is that correct?
#4662440 - 02/11/18 01:21 AM Re: Purolator failure? [Re: gtmaster303]
AntsinmyEyes Offline
Loc: Colorado
looks like a maintenance failure not a filter failure to me
1987 mazda rx7
2004 mazda rx8
1995 miata
2005 dodge ram
#4662442 - 02/11/18 01:34 AM Re: Purolator failure? [Re: gtmaster303]
69GTX Offline
Loc: Connecticut
I won't run a Pure 1 any longer than 4K miles while using Mobil 1 or other quality synthetic. Lots of cold starts and cold trips sounds like you should be on 6 month oil change regimen....5K-8K miles. Oil is cheap compared to your engine...at least if you do the OC's yourself (figure $20-$30 for synthetic oil and synthetic media filter).
2001 Lincoln Cont 4.6L DOHC/ 39K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
#4662485 - 02/11/18 04:54 AM Re: Purolator failure? [Re: bbhero]
car51 Offline
Loc: Southwest PA
Yeah last time I did one of those I used EDGE 0w40 and MANN filter
AMEN COLONEL!
2009 Toyota Camry LE
#4662499 - 02/11/18 05:52 AM Re: Purolator failure? [Re: gtmaster303]
wemay Offline
Loc: Southeast Florida
There is way too little information about this situation, and the information known points towards questionable regimen.
2017 Hyundai Sonata Sport 2.4L
2013 Hyundai Santa Fe Sport 2.0T
