gtmaster303
Originally Posted By: rooflessVW
Filter looks put through the wringer.
Start by using an appropriate oil. Mobil 10W-30 doesn't meet the specs for your vehicle and you've likely been beating it into Oblivion with your extended drains and usage pattern.
You need a Porsche A40-approved oil; ACEA A3/B4 at a minimum. Only use Mann, Mahle, or Hengst filters.
I would also look into replacing your filter bypass valve.
Porsche recommends Mobil 1 0w40 or 5w30 if I'm not mistaken
I highly doubt a 5w or 10w oil would make that big of a difference, even up here in the northeast, no?
