Ac Delco oil on Rockauto
by WiskyBadger. 03/21/19 11:09 PM
Old Laptop - Keeps Freezing - Help!
by reemoe2. 03/21/19 09:52 PM
Cinnamon Cake
by StevieC. 03/21/19 09:43 PM
AMALIE OILS
by kstanf150. 03/21/19 09:41 PM
oem filters
by mobilaltima. 03/21/19 09:34 PM
Magna1 10W30
by mobilaltima. 03/21/19 09:32 PM
Found triple threat
by deven. 03/21/19 09:26 PM
Chrysler Valvetrain week??
by clinebarger. 03/21/19 08:50 PM
Lisle funnel for radiator drain & fill
by paulri. 03/21/19 07:45 PM
Rattle in Catalytic Converter 2003 Suburban
by Fitz98. 03/21/19 05:59 PM
Mobil1 5W-30 EP, 8317mi, 2007 Prius Touring, 98133
by DuckRyder. 03/21/19 05:32 PM
Maxima Pro Plus 20/50 syn bike oil
by Truckedup. 03/21/19 04:54 PM
CHAMPION COS 3593A **NEW** CUT OPEN
by 53' Stude. 03/21/19 04:28 PM
NAPA PROSELECT 21348 CUT OPEN
by 53' Stude. 03/21/19 04:21 PM
Atlanta No Nonsense Honda dealer
by DuckRyder. 03/21/19 04:16 PM
Echo (PAS) - Good, Bad, Other?
by GemStater. 03/21/19 04:06 PM
Serpentine Belt - When To Change?
by Propflux01. 03/21/19 03:08 PM
Magnetic Out, ST in at Wally Auto Care Center.
by csandste. 03/21/19 02:26 PM
scottjeffrey, Mowata, LoneWolf04, Paperboy, Flinch
67579 Registered Users
72 registered members (aaronc7, allgm59, 97prizm, Aichiguy, 2010Civic, 8 invisible), 1,245 guests, and 65 spiders.
Topics286,216
Posts4,904,445
Members67,579
Most Online2,967
Mar 10th, 2019
how long do you let the charging vehicle run? #4530664
09/30/17 09:39 PM
09/30/17 09:39 PM
Houston, Texas
motor_oil_madman Offline OP
Houston, Texas
This kind of goes along with my other thread, but I didn't want to derail it. Anyways, as recommended on here I bought some of those 1 gauge battery booster cables that are like 1/2" thick andt cost like 60 bucks. How long do you let the donor vehicle run when jump starting someone? I've heard if your cables are thick enough you can just start the vehicle without even running the donor vehicle, but we let it run for like 3 minutes at a high idle and my truck started right up.
2007.5 dodge cummins 6.7 liter. Chevron Delo400 15w40. 7000 mile or 250-300hr intervals.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530665
09/30/17 09:40 PM
09/30/17 09:40 PM
Houston, Texas
Houston, Texas
The part that had me curious was that the cables on the donor vehicle side were pretty warm for the first two feet or so.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530671
09/30/17 09:48 PM
09/30/17 09:48 PM
MN
14Accent Offline
14Accent  Offline
MN
You were smart to buy the expensive cables. It never ceases to amaze me what passes for "jumper cables". Average starter draw is somewhere between 150 and 300 amps, depending on application. Assuming the "dead" battery is truly dead, you would need at MINIMUM 4 gauge wire, with 1/0 gauge preferable. [censored], I use a light 1/0 gauge to power just the subwoofer amplifier in my car, which pulls right around 100 amps when it's cranking out.
The heat in the cables is normal. Most likely due to resistance between the cable ends and the terminals. Did you jump the cummins in your signature? That thing will easily pull 250 amps while cranking.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2003 Cadillac Seville STS - The winter "beater", it uses the Volt's fuel
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530674
09/30/17 09:52 PM
09/30/17 09:52 PM
Houston, Texas
Houston, Texas
Yeah. I was worried it wasn't going to work because the donor vehicle was a honda pilot with a tiny battery. I guess its the alternator that does the work though. I bet those cheap 8 gauge jumper cables would have melted.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530675
09/30/17 09:53 PM
09/30/17 09:53 PM
Houston, Texas
Houston, Texas
It worked great and I was able to make the last ground connection to the lifting eye on the engine, which most engines don't have.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530688
09/30/17 10:19 PM
09/30/17 10:19 PM
ME
eljefino Offline
eljefino  Offline
ME
I try for a couple minutes. I've read that the jump donor should confiscate the jumpee's keys so they aren't in there hammering on their starter... and your alternator. I tell the recipient to hold off until I rev it then go for it... I figure my revving helps spread the load over all the sets of diodes in my alternator vs just one.
But I have fine luck with 10 gauge cables. When one looks at tables for amps and cable ratings there are assumptions about continuous use and voltage drops of only a couple percent. In reality if you can keep the suffering car from dipping below 9 volts or so during cranking, it'll catch.
Bigger cables are better, sure, but if they come with stiff clips or a poor interface to the terminal posts it's a problem.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530701
09/30/17 10:30 PM
09/30/17 10:30 PM
Deplorable in apple valley, ca
Chris142 Offline
Chris142  Offline
I let it run 10 minutes or so.
02 Wrangler carlube 5w30
87 F250 traveler 15w40
07 fjcruiser Chevron 10w30
Z400 castrol T 10w40
Can am maveric edge 5w40
57 case tractor 15w40
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530722
09/30/17 11:06 PM
09/30/17 11:06 PM
CA
raytseng Offline
raytseng  Offline
CA
1. you can just attach the cars together. both off. wait 2 min then start the dead car.
2. only if thsts not working then you should start the donor car.
3. better yet just get a jump pack instead of jumper cables.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530742
09/30/17 11:41 PM
09/30/17 11:41 PM
Staten Island, NY
michaelluscher Offline
Staten Island, NY
I give it 5 minutes
'06 Toyota Camry SE V6 3MZ-FE 100k
'01 Mercury Villager Estate VG33E 52k
'06 Ford Taurus SE Vulcan 60k
'13 Chrysler 300 3.6 Pentastar 230k
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530744
09/30/17 11:48 PM
09/30/17 11:48 PM
Waco, TX
Linctex Offline
Linctex  Offline
Waco, TX
6 gauge or lighter cables I call "Charging cables".
They will jump a vehicle with a battery that's .1 volt too low to start other wise.
I did know a single mom who left her dome light on all night.
She called me in a panic (from another state)...
I told her she had to convince the person jumping her car it would take more than 5 minutes.
It took 15 minutes to get her dodge caravan running again.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530807
10/01/17 02:16 AM
10/01/17 02:16 AM
Saskatchewan, Canada
Johnny2Bad Offline
Johnny2Bad  Offline
With good cables you don't need to run the dead vehicle at all, but if you want to high idle for five minutes on the start vehicle it's OK. Turn everything off (lights, heater, radio, etc) on both unless you need the flashers going on the start vehicle. Be sure to run the dead vehicle for at least a half hour after a boost ("jump" for American readers) and blip the throttle up to at least 2000 RPM if you intend to just let it idle, since some alternators won't charge until they hit about 1600~1800 first briefly.
'57 FL Straight 50 wt
'90 Miata 1.8L w/Rotrex Supercharger [Mobil1 0W-40]
'96 Ram 1500 [3.7L Mobil1 0W-20 / 1L 15W-50]
'01 PT Cruiser [Mobil1 0W-40]
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530809
10/01/17 02:25 AM
10/01/17 02:25 AM
Central Washington
Colt45ws Offline
Colt45ws  Offline
Central Washington
Generally I try right away and if it doesnt work, I wait a few minutes with the booster vehicle running.
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: how long do you let the charging vehicle run? [Re: Johnny2Bad] #4530955
10/01/17 09:05 AM
10/01/17 09:05 AM
Houston, Texas
Houston, Texas
I've heard that, but I didn't think it would work since the battery on the booster vehicle is only a little bigger than a riding mower battery.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530965
10/01/17 09:14 AM
10/01/17 09:14 AM
Boston, MA
HerrStig Offline
HerrStig  Offline
Boston, MA
Output over time is what starts a car, not physical size. A lithium pack can hold a lot of charge in a small space.
Re: how long do you let the charging vehicle run? [Re: motor_oil_madman] #4530992
10/01/17 09:36 AM
10/01/17 09:36 AM
ME
eljefino Offline
eljefino  Offline
ME
You want a surface charge on the dead battery. ~14 volts coming in on the cables does this faster than ~12.5. Having the electrons "that much closer" is beneficial.
