Originally Posted By: Ducked
Originally Posted By: Or
Jeez, you really need a torque wrench to get "lug nut" accurate for 60 or up to 100 ft/lbs?
You don't. Guesstimate the length of your ratchet arm or breaker bar, factor by that length and put the correct pressure on it by hand. E.G., put 1/2 as much pressure on an 18" breaker bar to get 60 ft/lbs as you would a a 9" ratchet to get 30 ft/lbs. A little practice with a single torque tool can educate your hand and senses. Then you can use the Mk1Mod0 eyeball to estimate the leverage and adjust accordingly.
This is not rocket science.
PS - I have that HF torque wrench and it works great; I have others to check it against for critical applications. I got it because it was cheap and I didn't fear dropping it on the concrete outside.
And I feel cheated because I paid $19! (kidding; a good value even then).
You're right. I looked at it this way. For lug nuts, how could I have gone wrong? There were plenty of positive reviews, my FIL had one for years w/o any problems at all, and friends had them. I said for $10, it will save wear and tear on my good torque wrenches when being dead on accurate didn't matter. This thing fit the bill exactly. In fact I found it to be very accurate in my occasional informal unscientific testing when I had nothing better to do with my time.
You seem to be missing or avoiding his point.
He's not saying that a cheap torque wrench is good enough.
He's saying that NO torque wrench is good enough. IOW, you don't need a torque wrench.
And you're right.
He's right.
Also neatly avoids the greasing/not greasing lug nuts "dilemma"
But lets not go
there again, eh?
Got ya! I was looking at it from torquing a lug nut perspective. Where you don't have to be dead on, and the cheapie wrench fits the bill nicely. I'd rather be a bit more in the ballpark, I don't guesstimate torque that well. OTOH I usually don't have too, I grab the torque wrench.
In fact I might be using it today if I can muster the enthusiasm to do front brakes on my Liberty. I might have two cups of black coffee after Church and go for it!
Fair enough. OTOH I sometimes see "gadget assisted breakages" on here where someone miss-set or miss-read a device, or it was just faulty. A lot of these could be avoided by just developing a feel for "good enough", which slavishly following the gadget tends to defeat.
I use one sometimes, (though never on lug nuts) and sometimes, if I really don't like the "feel" of what its telling me, I ignore it. IIRC I did that the last time I did the caliper bolts.
Could mean I under-torque stuff sometimes, but OTOH I don't break much, and not much falls off.
