Turbos in areas that get below freezing coupled with short trips are always a disaster.
Diesel or gas naturally aspirated is more reliable anywhere with a winter.
One of my patients was just telling me that her 2018 Chevy Trax (1.4 T) blew the turbo. $2800 I believe was what she said they weee going to have to pay. My cousins 2017? Hyundai Tuscan (1.6 T) blew the turbo at 95K miles. Some designs are certainly better than others, avoid the bad ones and MAINTAIN the good ones and I think you will have a good service life.Yeah, but that engine is from a different time period, and how to keep it alive indefinitely was a design criteria back then, and its relatively understressed. I don't think too many of the little whiz bangers in GM's new small SUV's are going to go 300k miles without some major repair....
Are there any small turbo engines in any common recent cars that have a good reputation for doing big miles without problems? Maybe GM's 2.0 after 2015? I dunno, I can think of a lot of turbo engines that weren't so good.
Idk VW has a pretty good track record. They have been doing it for a long time.It depends on the turbo. Mitsubishi single stage turbos are incredibly reliable and that's what Honda uses on their engines and you don't hear about issues with them and for good reason. But those junk American or German non single stage turbos will have a much higher chance of failing you during the long term ownership.
Or just avoid short trips? Not disagreeing with you on the short trip issue, but I have plenty of winter here, and I would not avoid a turbo because of winter--but to me, a short trip to the grocery store is 9 miles each way.Turbos in areas that get below freezing coupled with short trips are always a disaster.
To be fair - Hyundai/Kia can't build NA engines properly, either.In my dumb kid opinion, turbos are less reliable, but turbo engines are usually built better than naturally aspirated engines from the same engine family. And some people (Germans mostly) build better turbos/engines than other people (im looking at you kia)
Besides turbo engines are usually more fun to drive, who needs reliability?
You need to shorten OCI and replace the turbo oil feed line every 60K and that turbo will last. GM (in their infinite wisdom) routed the feed line behind the exhaust manifold, over the turbo. The heat literally cokes up the oil line in a short time.One of my patients was just telling me that her 2018 Chevy Trax (1.4 T) blew the turbo. $2800 I believe was what she said they weee going to have to pay. My cousins 2017? Hyundai Tuscan (1.6 T) blew the turbo at 95K miles. Some designs are certainly better than others, avoid the bad ones and MAINTAIN the good ones and I think you will have a good service life.
Really? I've been wondering why I keep hearing about those engines failing. What the hell, GM?You need to shorten OCI and replace the turbo oil feed line every 60K and that turbo will last. GM (in their infinite wisdom) routed the feed line behind the exhaust manifold, over the turbo. The heat literally cokes up the oil line in a short time.
The feed line is as cheap as doing a set of plugs and all the filters.
I've owned four different turbo cars and never had a turbo failure.
I bought a new 2014 Focus SE and had to look around to find a 5 speed M/T. It's only got 71K because my driving dropped after retiring in 2016. It's been extremely reliable and trouble free and still even has the original brake pads. Ford should have dropped the DCT and went with the 6F35 as soon as the issues showed themselves because it appears the DCT was basically unfixable due to its design (many had to be fixed numerous times),I bought this one new in '13 so just hit 10 years old last month. Had to really dig around to find a loaded SE so all possible options but with the 5 speed. It' really a good little car. My son loves it and actually is going to start autocrossing it this year...it's got springs/dampers, rear sway bar, and a tune (just lets you get some power from running 93).
The 6F35 had it's fair share of issues as well, though. In Ford's version of the 6F, the valve body bores would wear out and the trans would start being sluggish shifting. Typically from 1-2 and 2-3, sometimes into reverse. As the bore wore out, it would just stop shifting as it couldn't develop pressure. This issue is what sent my Fusion to the junkyard.I bought a new 2014 Focus SE and had to look around to find a 5 speed M/T. It's only got 71K because my driving dropped after retiring in 2016. It's been extremely reliable and trouble free and still even has the original brake pads. Ford should have dropped the DCT and went with the 6F35 as soon as the issues showed themselves because it appears the DCT was basically unfixable due to its design (many had to be fixed numerous times),
Ford lost a lot of future customers by refusing to admit failure of the DCT and moving on.....would you buy another Ford after the Focus DCT broke your heart?
I agree with you....comparing a larger engined Volvo turboed car, which have been out for decades with great reputations to a 1.5T from a domestic manufacturer installed in an SUV isn't apples to apples IMO. I went for the 2.5 Duratec in my Escape and I'm glad I did. Having said this I wish Ford sold the Fiesta ST with the 1.5T Dragon 3 cylinder here in the states. A small turboed engine in a light car is another story IMO.In my originally post i was referring to small engines with turbos 1.5L.
Not 2.5L and so on.
Sorry to hear that. What year was your Fusion? At what mileage did the trans fail at? Did you ever change the ATF? I ask because I have the 6F35 in my Escape. I'm at 66K and have changed the ATF 3 times already and I'm hoping it last as long as the 2.5.The 6F35 had it's fair share of issues as well, though. In Ford's version of the 6F, the valve body bores would wear out and the trans would start being sluggish shifting. Typically from 1-2 and 2-3, sometimes into reverse. As the bore wore out, it would just stop shifting as it couldn't develop pressure. This issue is what sent my Fusion to the junkyard.
It was a 2011, and I changed the ATF every 100k. Never looked burnt or smelled burnt. My buddy at a dealership told me that if my trans was affected it *should've* failed between 100 and 150k. What saved mine was that all my mileage was highway, so I stayed out of the lower gears. The trans finally started having the issue at 320k, and I junked it at 324. Which was a shame, as the 2.5L NA engine Ford put in that car is as reliable as the sun, and even at the end it burned less than 8oz of oil over a 10k mile OCI. I miss that engine.Sorry to hear that. What year was your Fusion? At what mileage did the trans fail at? Did you ever change the ATF? I ask because I have the 6F35 in my Escape. I'm at 66K and have changed the ATF 3 times already and I'm hoping it last as long as the 2.5.
While I don't think the 6F35 is a trouble prone transmission I do realize it's gonna need PM to get it to last over 300K (which is my goal and I think you did pretty good to get to 324K with 100k A/T changes) I did my first D&R at 16K and the fluid looked brownish but didn't smell burnt (people say it is normal for the Mercon LV to turn brownish). I did the second D&R at 32K and it was slightly less brownish. I did the 3rd D&R at 49K and it was even less brownish and actually looked red. I plan on doing D&R's every 25 to 30K from now on....I hope this makes the tranny last as long as the 2.5.It was a 2011, and I changed the ATF every 100k. Never looked burnt or smelled burnt. My buddy at a dealership told me that if my trans was affected it *should've* failed between 100 and 150k. What saved mine was that all my mileage was highway, so I stayed out of the lower gears. The trans finally started having the issue at 320k, and I junked it at 324. Which was a **** shame, as the 2.5L NA engine Ford put in that car is as reliable as the sun, and even at the end it burned less than 8oz of oil over a 10k mile OCI. I miss that engine.
I did 2 D&Rs. One at 100K and the next around 200K. Each one was a 3x drain and refill to get as much old fluid out as possible. And yea - Mercon LV doesn't hold it's color long at all. So it's kind of a false flag to rely just on color with that fluid. The dye package just wears out quickly LOLWhile I don't think the 6F35 is a trouble prone transmission I do realize it's gonna need PM to get it to last over 300K (which is my goal and I think you did pretty good to get to 324K with only one A/T change) I did my first D&R at 16K and the fluid looked brownish but didn't smell burnt (people say it is normal for the Mercon LV to turn brownish). I did the second D&R at 32K and it was slightly less brownish. I did the 3rd D&R at 49K and it was even less brownish and actually looked red. I plan on doing D&R's every 25 to 30K from now on....I hope this makes the tranny last as long as the 2.5.
Except in my case I changed the turbo oil feed line at 95,000 miles and it was a clear as the new one. This was using basically any oil at the time and 5-6,000 mile OCI. I follow the Trax and Cruze forums and turbo failure is not as rampant as someones brothers, customer, cousins, roommate make them out to be. Not saying they don't go bad, but other stuff breaks too.You need to shorten OCI and replace the turbo oil feed line every 60K and that turbo will last. GM (in their infinite wisdom) routed the feed line behind the exhaust manifold, over the turbo. The heat literally cokes up the oil line in a short time.
