Originally Posted By: bubbatime
Originally Posted By: BrianF
I believe the shotgun, whether it be 12 or 20g is the best answer. Unless you hit your intended target, nothing matters. Something with a wide spray pattern works better then one small projectile.
Home defense scenarios are going to be under 12 feet for most engagements. Many engagements will be within 3-5 feet. There is no meaningful spread at 12 feet and less, and certainly not a wide spray pattern.
If one is afraid of over penetration use some sort of lead bird shot.
Bird shot is for tiny little birds. Not for defense, if you want to live another day.
The second main thing is ease of use. Shotguns are great, big rounds and easy to load. Cycling a pump in a stress situation is easy.
Most trainers will advise that the pump shotgun is the hardest home defense gun to master. Its takes a lot more skill, training, and practice to master a pump shotgun that it does a pistol or carbine. Most people can become "OK" with a pump gun with a limited amount of instruction, but if they have a malfunction, they might as well have a club in their hand as it will take an untrained person way too long to clear, if they can clear it at all. Many folks short stroke a pump shotgun in stressful scenarios, which jams up the gun.
At different matches I've done it's pretty common for pump shotgun users to not cycle the action or to short stroke it under stress. And that's the stress of being timed and shooting for score.
The other problem with shotguns is the limited magazine size and the long reload time. Plus it's hard to carry reload ammo. With a magazine rifle I can easily drop a spare magazine in a pocket. Shotguns shells have to be grabbed individually and are bulky.
BSW
