weaponoffreedom
- Joined
- Nov 28, 2021
- Messages
- 809
I can run my benelli m4 entry just fine. Loading, select slug, support side, under nods, white light, you name it. However...
I have moved more to an 11.5" 5.56 gun as a do all. It allows me to reach across my yard and deal with a coyote as easily as cleansing my livingroom. Also, with a can, its far less obnoxious than the m4 entry even using le133.
PCCs just kindof...nah. They don't give you the projectile volume of a gauge, or the damage of the 5.56. I have zero application for a PCC.
i have done some terminal ballistic testing with 9mm out of 16 inch barrel, and although not rifle or shotgun power, fmj 9mm out of a longer barrel has some effects over the pistol length.
i have never heard or seen anyone get up after taking a 00buck, 556 and 9mm, is a different story
I think for your dual role a short AR is optimal, especially when you have problems with coyotes.
do you have a thermal?
