OVERKILL
$100 Site Donor 2021
Originally Posted By: unDummy
Just about any Netgear, Linksys, Dlink... router will be fine.
Since both of my laptops support "N", I picked up an "N" router. But, you can save some money($20) if your wireless card is only "G".
I've never had or seen issues with the above brands. They seem to be well supported with firmware updates from the factory.
D-Link is probably the WORST in terms of releasing firmware upgrades. WPA support? No, that router is a year old, it gets to keep 2005 firmware with WEP!
I've witnessed this OVER AND OVER AND OVER again with them. SMC is arguably just as bad.
They (SMC) had a high-powered (and expensive) G-router that would drop connections if encryption was used and you had a number of wireless clients. It would just stop giving out IP addresses to new clients. A hard-reset would get it "working", though the same limit still existed. This bug existed in ALL THREE firmware versions, it was a WELL DOCUMENTED ISSUE, and they simply DID NOT fix it. They just let it die off as the router became obsolete.
Given my area of employment, I get to deal with hundreds of these things annually. Some are great, some are not so great. I have a lovely story of a dead Linksys MIMO router that had to be sent back twice with a 30-day turn-around on it every time that eventually resulted in a version upgrade because the owner was going ballistic. My point is, that I deal with more routers in the course a week than most will touch in their life. It comes with the territory. And I'm not saying all the products from a certain brand are bad; they aren't! And many DO work great.
But from my position, it is very easy to plot the failures and the models of brands with failures and contrast them to each other to form a recommendation, which I have already done in this thread.
NETGEAR makes some very nice "business-grade" equipment for example; but you pay for it.
As far as consumer products go, the experience I have had with ASUS has been remarkable. That is why I recommend them.
I would NEVER recommend a D-Link product. They rank that lowly with me. If somebody couldn't get an ASUS, I'd tell them to get a Linksys or Netgear instead.
The WL-520GU that has been discussed in this thread is a fantastic device. And if there WAS an issue with Comcast compatibility, ASUS will have addressed it with a firmware upgrade already.
Comically, this device has been in production since '07. There have been 7 firmware releases since then, the most recent being the 14th of this month
