I know folks have been talking about re-using oil with under a few thousand miles for lawnmower,car, truck and other uses. I built a toliet paper synthetic oil recycler out of the following:
1-6ft piece of 4inch ABS
2-4inch ABS end caps.
2-toliet paper hole cover (tylenol measuring cup)
2-rolls singleply toliet paper.
drill a couple of holes to hold the 6ft abs pipe in the air from some rafters. push the cap tightly on the end on the bottom. unravel and tightly place 2 toliet paper rolls midway. top roll and 2nd roll have the hole cover inplace. push the rolls down about 2.5 to 3ft. hang the abs pipe. pour 5qts of used synthetic oil in the top, cover with abs end cap. let drain for 24 hours....clean, clean, fresh synthetic oil for your re-use!
