Would running a euro oil help with this to some degree?Even if it stays the same, it poisons the cats.
A euro 5w-40 might help.Would running a euro oil help with this to some degree?
???Is it white
Is that same same 1.5L turbo that's in my wife's 2018 Equinox? It currently has 63,000 miles and hasn't burned any oil during the 5,500 mile oil changes. Most of the miles are highway though.That is a known oil burner motor and that is what I see in them. 1 qt/5k miles is actually a good report for that motor. Keep an eye on it.
I believe GM recommends 5w30 in the 2018+ 3rd gen with 1.5TBoth our 2015 and 2017 burn around 1qt /5k miles. Bumping up to 5w30 did improve it a bit.
Typical of todays cars with slipper-skirt pistons, low-tension rings and high piston speed with long stroke. What oil grade?I'm just worried if it uses oil when new what will it use when it has 70 or 90,000 miles on the odometer.
Post in thread 'Lets talk about new vehicles' https://bobistheoilguy.com/forums/threads/lets-talk-about-new-vehicles.338563/post-6440879
Yes it is. Proper maintenance is key and you are doing a great OCI for that motor. I have replaced 2-3 of these motors in Malibus on pre '17 model years. There were changes in 17/18 model year that seems to have helped a bit. I service a 2019 Equinox with 78k and oil changes done off the OLM system and that customer is using approx 1 quart in 4500 miles and that isn't so bad as long as people check the oil and top off. It's when they don't check the oil during long OCI's that they run low and cause the additional wear over time and suddenly they have a big oil burning issue or locked up motor.Is that same same 1.5L turbo that's in my wife's 2018 Equinox? It currently has 63,000 miles and hasn't burned any oil during the 5,500 mile oil changes. Most of the miles are highway though.
That is a very solid point and directly related to oil burning and sitting here pondering - I think the #1 code I see is P0420/430 convertor codes and I have changed a fair amount of convertors too. This oil burning issue I am surprised the EPA doesn't look at that metric as pollution.Even if it stays the same, it poisons the cats.
Wait so he told you about the oil burning issue, you still bought the vehicle and gave them bad surveys? Kinda a **** move if I’m reading correctly.back in 98 I was buying a new 3/4ton chevy, the sales guy said they loosened the rings and they burn more oil. I thought the guy was pulling my leg,
But it burned 1/2 quart every 1500 miles, I tore their survey a new A$$ every time I got one.
They did it for mpg, which really didnt help much, I rather had a tight motor that didnt burn oil.
To me any oil usage is unacceptable.Wondering what you all thought of what you think is normal oil usage for newer vehicles these days. I have a 2023 Chevy Equinox 1.5 liter turbo with 17,000 miles and it has used approx. 1 quart of oil per 5,000 miles since new. Do you think this is normal?
Before the Equinox my wife had a 2009 Saturn Aura with the 3.6L V6 and I never went off of the OLM due to the fact that there were a lot of timing chain issues with extended oil changes in the 3.5 and 3.6 engines. I did 5-6K changes and when we traded it in with about 123,000 miles it didn't burn oil or have any timing chain rattles. I kinda miss that car since it was an absolute rocket.Yes it is. Proper maintenance is key and you are doing a great OCI for that motor. I have replaced 2-3 of these motors in Malibus on pre '17 model years. There were changes in 17/18 model year that seems to have helped a bit. I service a 2019 Equinox with 78k and oil changes done off the OLM system and that customer is using approx 1 quart in 4500 miles and that isn't so bad as long as people check the oil and top off. It's when they don't check the oil during long OCI's that they run low and cause the additional wear over time and suddenly they have a big oil burning issue or locked up motor.
The typically way a converter is deactivated is through temperature, not oil burning. While burning oil will eventually deactivate the converter. Temperature does it much fast. When a vehicle is certified by the EPA, the OEMs typically use a temperature aged converter equivalent to 150,000 miles.That is a very solid point and directly related to oil burning and sitting here pondering - I think the #1 code I see is P0420/430 convertor codes and I have changed a fair amount of convertors too. This oil burning issue I am surprised the EPA doesn't look at that metric as pollution.
I have a similar scenario having purchased a new 2008 CTS 3.6DI in 2008 and doing M1 oil changes every 5-6k miles. While the timing chains did need to be done anyhow at around the 45k mark it was covered under warranty. The car now has 204k miles and just now started to burn oil at about a quart every 3-4k miles. Keeping fresh synthetic oil in there (never running low) and frequent changes are the way to a long life 3.6L.Before the Equinox my wife had a 2009 Saturn Aura with the 3.6L V6 and I never went off of the OLM due to the fact that there were a lot of timing chain issues with extended oil changes in the 3.5 and 3.6 engines. I did 5-6K changes and when we traded it in with about 123,000 miles it didn't burn oil or have any timing chain rattles. I kinda miss that car since it was an absolute rocket.
