The N57 is lighter than the M57. Off the top of my head that's really the only difference when it comes to the internals. Both power plants are sold at essentially the same power levels. (Ex In the U.S. the N57 makes a tad less hp/more torque than the M57 it replaced.
BOHICA!
Of course the parts aren't going to be identical. The newer block is lighter which obviously required design changes to the block itself (changes in mounting points) and other effected parts. Now what is interesting is that the part nos for the bearings, crankshaft, etc differ between the N57 and the N57S. I perused the parts myself and it appears that the the bearing tolerances between the N57 and N57S are almost identical.
In any case with all these differences the N57S still runs on the same oil (LL04) as the lower powered N57 and older M57.
https://www.newtis.info/tisv2/a/en/f32-435i-cou/repair-manuals/11-engine/11-40-oil-supply/1PSryV8 Clearly BMW believes the LL04 spec is sufficient for a wide range of engines with differing levels of torque.
Btw... I'ts just silly to suggest my comparison was akin to comparing .the M3 to the 335i. S55 (although based on the N55) in the M3 is a completely different engine. You can tell by the naming convention: N55 vs S55 N57 vs N57S The M division just tweaked the N57 for the tri-turbo setup rather than spend the resources to design a M specific diesel (aka S57)
The comparison I was talking about was my modified M57 and the N57S (M550d) which YOU brought into the discussion. That was the comparison YOU made to justify the use of LL04 in my modified M57. The S55 and N55 comparison is not that silly when you bring the goal posts back where they started with your original argument. You can argue that the M57 and N57S are even more unique than the S55 vs N55 analogy - and you would be correct.
The M57 and N57S ARE two very different engines - which I pointed out in more than one post - even after you stated that other than the block being lighter it was the only difference when it came to the internals (your own words - go back and read them) - which I demonstrated was in fact (through an exhaustive parts comparison) an incorrect statement. Furthermore, while "bearing clearances" may be similar when comparing the N57 and the N57S, they are different bearings with likely different composition - and I would be willing to bet the oil pump on the S version has higher volume and pressure output to provide the desired clearances with the same oil in an engine with significantly higher output. While the N57S is very similar to the N57, you tried to rebase your argument by shifting the original comparison.
The fact remains comparing a modified M57 to a factory high output N57S for the basis of your oil argument was beyond flawed from the get go.
Perhaps you should stop bending over - that's why it keeps coming your way.
Actually I said "that's really the only difference". Both are 3 liter, I6 diesels with same bore/stroke and produce approximately the same amount of power. The N57S makes more power because of the 3rd electric turbo and higher PSI fuel injection system. That's not to say that the M57 couldn't make the same amount of power if it also had a 3rd electric turbo and same injection system. In any case all of these engines use the same oil which means they're not that unique.
Keep on rollin' son thinking you have something "special" and stop being so --cking dense.
Peace out sugar cookie
