StevieC
Originally Posted By: i_hate_autofraud
Hey StevieC,
If you're north of Barrie Ontario, then I'd do the heaters for sure, OR use full synthetic oil, which I changed over to.
I put my dino oil in a cup and a second cup of full synthetic in the freezer and then checked the viscosity after 2 hours,
wow! was the dino oil stiff! The synthetic was still runny! I'll never go back. At this point a heater is no longer needed!
I also looked at bypass filtering, but there are draw backs, more dry start, can't get out ALL the old oil out during an OC,
so I gave up on that and used a pair of FilterMags, oil stays clean for 5-6 months after an OC, better then I could have hoped with a bypass filter!
OIL FILTERING: FULL FLOW and BY - PASS
https://app.box.com/s/m8nyfg0we1oq9o2s3qwgsj62f3z3422d
FILTERMAG vs HOMEBREW
https://app.box.com/s/uxvu8dmscf5wcgftutdm0ejqwgn86tw7
Where my system will be located and the short hoses required I'm not concerned about the remaining oil in the system.
As for location, I'm not far from Niagara Falls and so the temperatures here are mild until February but with bypass I don't want it running without filtration any longer than it has to so a pan heater is a good option for that.
Thanks for the links. I read the Filtermag one already but I will read the other one when I'm home today.
Hey StevieC,
