Another good point, have a freezer or a refrigerator in there. They will not need to run much but will also help keep the interior ever so slightly warmer
It's not cold. That's the whole reason everything is sweating. It was 22 degrees a week ago and now it's 68 degrees.A dehumidifier is probably going to burn as many electrons as heating but it will add sensible heat to the garage. I would just pop a window or the garage door.
Cold air is drier
Both. Warmer air has a higher moisture capacity and a dehumidifier strips the moisture out of the air. End result is warm dry air that wants to suck up moisture, not precipitate it.Well every piece of iron in my garage is sweating ... since it went from 40 degrees to 65 overnight. Kind of strange because imo it wasn't that big of a jump. Anyways, I would think if it had an electric heater to warm it up a couple degrees that would help things out, but would a simple dehumidifier work to just keep the humidity level down? We have a ton of humidity even in the winter on the gulf coast. That would be way cheaper than heating. Opinions? The garage itself isn't sweating other than the concrete floor in a couple areas.
Ahh okay so no air leaks from the warm/humid house into the cold garage. In any case my comment still stands regarding the dehumidifier. Garages are by design leaky and damp. The slab and tools are still cold enough to allow water vapor to condense out on the surface. Either keep a garage window or door open to reduce the temp delta or fire up a dehumidifier and start dehumidifying the outside (garages are considered "outside"). If you want to get fancy pay a company to install a wall mounted minisplit in the garage.It's not cold. That's the whole reason everything is sweating. It was 22 degrees a week ago and now it's 68 degrees.
Dehumidifiers take the water out of the air and puts it in a bucket or drain line. Heaters allow the air to be warmer but do nothing with the water molecules.A dehumidifier is probably going to burn as many electrons as heating but it will add sensible heat to the garage. I would just pop a window or the garage door.
Cold air is drier
Well sure but remember dehumidifiers add a little sensible heat to the room.Dehumidifiers take the water out of the air and puts it in a bucket or drain line. Heaters allow the air to be warmer but do nothing with the water molecules.
OPs issue is all his furniture-- toolboxes etc are metal, hold cold, and cause moist tropical air to condense on them. He needs the dew point lower than the coldest thing in the room. Adding heat to a particular volume of air doesn't change its dew point much, though its relative humidity will change.
how long do those last?All good options above. I didn’t want to run a dehumidifier in my garage during humid summer days so I buy a few 4 lb Damprid buckets and run a small fan to circulate the air. Works well for me.
