Originally Posted By: Snagglefoot
OK great. It's my lunch hour in Calgary so I am dedicating it to this while I each my sandwich.
I tried to find some info on the Volt. I came across a forum where the owner had a Volt and said they can get 50 miles from a charge. They didn't elaborate on speed, or city driving etc. So let's use 50 miles. They said they charge is on a 120 V outlet for 13 hours and it charges at 12 Amps. So Power = I x V or Watts = amps x volts. I is 12 Amps. V = 120 Volts. 12 x 120 = 1440 Watts. Ok, now we convert 1440 W to kw by dividing by 1000. 1440 kW/100 = 14.4 kw. Assuming the battery is 100% efficient (which it really is not, but close enough) 14.4 kw x 13 hrs is 187.2 kwhrs of energy.
Almost. The first gen Volt has a 16 kWh battery, in 2013 I believe 10.5 of that is usable. The usable amount increased twice through production. Also, the car can use UP TO 12 amps while charging, however the car decides how much to use at any given time. Lithium batteries don't like being given max charge rate as they approach full, so assume it starts at 12A and drops to around 3A for the last few percent.
It's hard to say exactly how much it will cost to charge it daily or to predict range due to temperature, driving style, and average speed. It's all a learning curve for me. Good thing I love learning about cars (unfortunately I hate math, so buying a car that almost begs you to keep track is a bit of an oxymoron).
Speaking of math I corrected a math error, finished off the calcs and resubmitted the findings. Please see it in my previous posting. Thanks. Sounds like you are going to be happy with your gasoline savings.
SF
Actually, that fuel price you found is low. St. Paul might be cheaper, but in Minneapolis I pay between $2.54 and $2.61. So 25 to 35 cents more. Guess that just swings things even more in my favor!
