Hey man, the camrys gonna be the daily. BMW will be the fun/weekend car
I'll be in it for 3 daysWho wants a boring daily? You're in it...DAILY!!!
So how does that work? Do you drive in a non-boring fashion? Like, just nail it and leave every stop in a cloud of rubber dust? Speed up every time someone tries to pass you? Brake check anyone following too close? ok not that, that's a fast way to regret.Who wants a boring daily? You're in it...DAILY!!!
Very true. But depends on the commute. My old '00 Camry would be fine in the country side if I just got it up to 65 mph, set the cruise, and relaxed for the drive. But I need to merge onto the freeway, which shortly comes up on traffic, then move over a couple lanes where you need to go from 5 mph to 65 mph reasonably unless you want to get rear-ended. Don't need to be a rocket but wow that old Camry has got an anchor tied behind it by now.Define slow. If you refuse to drive anything that is faster, how do you know it's actually feels slow?
True. One of the short on-ramps down in MA had me rethinking how to go in that direction. Yeah, this car is seriously lacking 0-60, and let's not talk about 0-80.But depends on the commute.
My (by all accounts here) slow car is still entertaining enough at extra legal speeds. I mean, toss in some wheel shake, something that sounds like crank bearings spinning on the wrong axis, and a tendency to change lanes in the gentlest of breezes... what's not keeping me fully focused on the job at hand?
There’s just something about that charm though knowing you’re in a car that no matter how hard you try, you can’t killA car that is fun to drive has nothing to do with being a jerk and not letting someone pass or brake checking. I've had way too many cars that were unbearably slow to the point of being dangerous and there was nothing fun or entertaining about them, total penalty boxes.
So what is an entertaining car? what does it do to make it entertaining? or what are you doing to make the drive enjoyable?A car that is fun to drive has nothing to do with being a jerk and not letting someone pass or brake checking. I've had way too many cars that were unbearably slow to the point of being dangerous and there was nothing fun or entertaining about them, total penalty boxes.
No. The sludge problem occurred when cheap bulk dino old was used and not changed often enough. Many owners went by the owners manual's 7500 mile oil change intervals. You know how that goes with the average driver, they will stretch it to 9 or 10000 miles, it will run a quart or so low on oil for a while, then they get the oil changed at a local quicky lube, and then after 70000 miles or so of doing this they have a sludge problem. The 4 cylinder had the same problem, but not to the extent of the V/6. The problem was not limited to Toyota either, other auto manufacturers also had this problem, most notably Nissan and Chrysler, and the problem isn't a new one, Ford had this problem on their Windsor V/8s all the way back in the 60s and 70s.Do all the V6s have sludge issues and what have you?
I totally agree. The Avalon < V6 < 4 cyl thing in older car is definitely true as the target buyers definitely want lower cost of ownership than comfort, or they would not buy something that old in the first place.I like the 4 cyl model way better. Super easy maintenance. If it shifts fine you can bring it back with a couple tranny fluid changes, and also get it right as rain with new timing belt (and driven accessories if you so want.) Even if you hire it out the 4 cyl will come in way cheaper.
I had the V6, plenty of punch. IIRC premium fuel helps with power on that motor. Never really used the power, so, meh. Agree on checking the alloys for wear-- that dealer was up to some shenanigans to be sure.
Ironically the 4 cyls are worth more (IMO) than the V6s once they're this age because practicality beats fashion. Dealers that want more money for the V6 are deluding themselves.
In another spot of irony, the extended wheelbase Camry better known as the Avalon is even cheaper at this vintage, as they were originally owned by more wealthy people who wanted something understated and "reliable" (simply by being a brand new Toyota). Few want 15+ year old Avalons so their actual sale prices are in the pits.
Seller has a good rating, 48 reviews with a 5/5 score. Plus car looks real good. Wish the description was in lower case and a little more detail. But car looks super clean and glossy.
so you are considering years beyond 97-02? I think that is smart for a few reasons, most 97-02's are beat, but you'll find many more 03-11's. Some 4 bangers had oil consumption issues but your a BITOG member and that gives you luck. Also, consider the Lexus instead if you have the budget. It will feel more like the bmw.
There are some 07-09 Camrys. A bit over budget but if I can find the right one, I'll pull the trigger.so you are considering years beyond 97-02? I think that is smart for a few reasons, most 97-02's are beat, but you'll find many more 03-11's. Some 4 bangers had oil consumption issues but your a BITOG member and that gives you luck. Also, consider the Lexus instead if you have the budget. It will feel more like the bmw.
So, he's charging $500 for labor?
$500 labor for both of those services is a bargain.I spoke to the mechanic that worked on my dad's old Camry in regards to how much he'd charge for the timing belt, water pump, and all 6 spark plugs on the 99 Camry. He quoted me $900 for parts plus labor. He's an ex Toyota Mechanic.
Idk why but I feel like $900 is a lot for the timing belt and all 6 spark plugs. I can get an asin timing belt kit, NGK plugs, and PRESTONE prediluted red coolant (2 gallons) for $192. Everything off Rockauto. He said he was going to use the Asin timing belt kit, OEM Toyota spark plugs, and OEM Toyota coolant and give me a 1-year warranty if I go with him.
So, let's say $400 for OEM Toyota stuff. So, he's charging $500 for labor?
