I used this oil based on everyone's recommendation here as previously my car has ran for 158,883 miles using conventional Castrol GTX 20W50 oil most of its life.
I had to rebuild my head gasket after it blew up when I added Royal Purple Purple Ice coolant additive to my cooling system. It did not mix very well with Mercedes coolant and actually turned into a thick greasy jello. I tried flushing it 60 times but could not get it out. It blew my Behr radiator 2 times and 1 heater core. Ended up costing me a ton of money. Lesson learned. RP would not help me with the matter and even blamed me for using their product wrong. Anyways I diverge.
So after the rebuild I decided to use Mobil 1 0W40 since everyone has been giving such good reviews of it. It made my car very noisy and the gas mileage went down. The best I could do was 17 or 18 mpg each tank. My car normally gets 21-26 depending on highway driving. Its weird for me to get such bad gas mileage. So today after only 1500 miles on the 0W40 I went back to the thicker stuff- M1 15W50. Hopefully this will cure some of the ills my little car has. When I pulled the magnetic oil drain plug out there was a good size black ball of metal stuck to it. I wonder if the thin oil caused the older engine some wear? It has to be iron because the aluminum in the head will not stick to magnets.
Anyone else have issues using thinner oil in an older Mercedes inline 6 engine? My car is a 1993 190E 2.6. Please feel free to discuss.
