Good morning folks. I’m in need of some kia/Huundai crush washers. Where do you folks get them?
Thank You all in advance sir
Very good sir. Thank You12 Pcs. 18mm Oil Drain Plug M18 Crush Washers Fits: Kia, Hyundia, Honda & Others | eBay
O.E. Spec. High Quality Aluminum Part.www.ebay.com
True. The girlfriends Hyundai has 4 culinder and takes Fram 9588 filter so I need crush washers.every time i’ve done a KIA oil change that has a cartridge filter, the crush washer has come with the carquest filters i buy. on second note, you should be able to find crush washers in the drain plug section at autozone
I received these and they are not the correct ones at all. I notified seller and already sent them back. He needs to correctly say what are for.12 Pcs. 18mm Oil Drain Plug M18 Crush Washers Fits: Kia, Hyundia, Honda & Others | eBay
Where to you buy yours? Got screwed over by seller on eBay. Never againI go with an aluminum or copper drain plug washer/gasket, not the crush type. I reuse them forever, and they always seal 100%.
On most KIA/HYUNDAI’s oil pan crush washer is 17MM. eBay seller just said “fits KIA/HYUNDAI and nothing else.I'm pretty sure the engine oil drain washer is 14mm. I think the 18mm washer is for the transmission drain plug.
Local auto parts stores or Amazon has many to choose from. Read reviews on Amazon.Where to you buy yours? Got screwed over by seller on eBay. Never again
