Prove they aren't...
You started the thread indicating that you wanted to get a NA motor b/c you feel they are more reliable/will last longer. I questioned that assertion. You told me to prove that turbos are as reliable. I ask you the same. I posted a funny meme. While it is certainly true that you can't break a turbo if you don't have one, I'm not convinced in 2023 that a turbo engine won't last as long as a NA motor for the typical life that most people are keeping their vehicles. It's like the posts about auto stop/start and all the folks that think it kills your starter - where are all the failures?Prove they aren't...
I don't think either of us can prove our point. Mine is based purely on the fact that a turbo adds a complexity to an engine that it otherwise doesn't have without a turbo, therefore it's more prone to failure. I think the variable that can't be proven is how much more likely a turbo engine is to experience a failure. I agree turbos have gotten much better, and more reliable in recent years as their use becomes more wide spread, but the fact remains, it still adds a possible failure point to an engine that an NA engine doesn't have...You started the thread indicating that you wanted to get a NA motor b/c you feel they are more reliable/will last longer. I questioned that assertion. You told me to prove that turbos are as reliable. I ask you the same. I posted a funny meme. While it is certainly true that you can't break a turbo if you don't have one, I'm not convinced in 2023 that a turbo engine won't last as long as a NA motor for the typical life that most people are keeping their vehicles. It's like the posts about auto stop/start and all the folks that think it kills your starter - where are all the failures?
Even naturally aspirated engines are pretty complex these days. Dual overhead camshafts, variable valve timing, long timing chains and all the associated hardware, etc. A turbocharged engine would certainly be a bit more complex but I'm not sure it's all that significantly so and it would typically have beefed up internals to handle the boost also. That being said, life is short. If buying something naturally aspirated makes you sleep better at night, it's only money.I don't think either of us can prove our point. Mine is based purely on the fact that a turbo adds a complexity to an engine that it otherwise doesn't have without a turbo, therefore it's more prone to failure. I think the variable that can't be proven is how much more likely a turbo engine is to experience a failure. I agree turbos have gotten much better, and more reliable in recent years as their use becomes more wide spread, but the fact remains, it still adds a possible failure point to an engine that an NA engine doesn't have...
That's unusual.My sister's 2015 Highlander with 67,000 miles on it, dumped the water pump a few months ago. Overheated to the point that the AC shut off and the dash started dinging before she realized what was happening. Toyota checked it out (I told her to have them do a coolant pressure test, don't know if they actually did it), fixed the water pump and changed the oil. I'm waiting for one of the head gaskets to fail.
Water pump failures? Pretty common on the early 2GR's, not as common now. But still happens.That's unusual.
At least in the Tacomas the 3.5L needs higher rpm’s to make power. My 4.0L has been rock solid and makes power down low. I’m curious to see the reviews on the 2.4LT when it comes out. I got a buddy who has the 2.7LT in his GMC truck and absolutely loves it. Tows his boat and camp with ease.
The last timing belt on a Highlander was the 2007 3.3. In 2008 the switched to the 3.5 with the chain.There hasn't been a Toyota engine with a timing belt for decades...
I'm sure the turbo owners will be quick to say he's full of beans...Scotty Kilmer says a larger displacement NA engine will outlive a smaller turbo engine.
Less pressure, less heat, less stress.
Well, he does make a lot of noise.I'm sure the turbo owners will be quick to say he's full of beans...
And he also knows what he's talking about most of the time...Well, he does make a lot of noise.
