Need some help.
I am draining and filling sis chevy 2016 equinox.
The transmission is 6t45.
It has less than 20k miles but i would like to do yearly drain and fill on the atf after the honda accord experience
Q. I have access to valvoline full synthetic dexron vi at 5 bucks a quart. But the flash point is not as high as mobil semi syn. I think 200c v 220c for mobil 1. Then there is ac delco full syn. Dexron vi. So any advice on which you would use.
Q. Anyone drained a 6t45 cold like in the morning after sitting all night and measured how much came out. I plan on filling exactly the same amount as that came out and avoid messing with the check level hole on the side. Thanks GM for the dipstick absence.
Thanks
Thanks
