I think you are quoting pennzoil from a long time agooo.
The one below is not exactly what you want but shows pennzoil atf with gtl.
I dont know how to upload the file.
I got it from homedepot.com
I also recall seeing quaker state ultimate atf with gtl. Exact same as pp.
I will try to find the exact one.
SAFETY DATA SHEET
According to OSHA Hazard Communication Standard, 29 CFR
1910.1200
1 / 15 US
Version 1.2 Revision Date: 07/07/2015 Print Date: 07/08/2015
SECTION 1. IDENTIFICATION
Product name : Pennzoil Synthetic Multi-Vehicle ATF
Product code : 001E7844
Manufacturer or supplier's details
Manufacturer/Supplier : Shell Oil Products US
P.O. Box 4427
Houston TX 77210-4427
USA
SDS Request : (+1) 877-276-7285
Customer Service :
Emergency telephone number
Spill Information : 877-504-9351
Health Information : 877-242-7400
Recommended use of the chemical and restrictions on use
Recommended use : Automatic Transmission Fluid
SECTION 2. HAZARDS IDENTIFICATION
GHS Classification
Not a hazardous substance or mixture.
GHS Label element
Hazard pictograms : No Hazard Symbol required
Signal word : No signal word
Hazard statements : PHYSICAL HAZARDS:
Not classified as a physical hazard under GHS criteria.
HEALTH HAZARDS:
Not classified as a health hazard under GHS criteria.
ENVIRONMENTAL HAZARDS:
Not classified as an environmental hazard under GHS criteria.
Precautionary statements : Prevention:
No precautionary phrases.
Response:
Storage:
Disposal:
Other hazards which do not result in classification
Prolonged or repeated skin contact without proper cleaning can clog the pores of the skin result-
ing in disorders
SAFETY DATA SHEET
1910.1200
2 / 15 US
Used oil may contain harmful impurities.
Not classified as flammable but will burn.
The classification of this material is based on OSHA HCS 2012 criteria.
Under normal conditions of use or in a foreseeable emergency, this product does not meet the
definition of a hazardous chemical when evaluated according to the OSHA Hazard Communica-
tion Standard, 29 CFR 1910.1200.
SECTION 3. COMPOSITION/INFORMATION ON INGREDIENTS
Chemical nature : Highly refined mineral oil.
Synthetic base oil and additives.
The highly refined mineral oil contains w) DMSO-
extract, according to IP346.
Hazardous components
Chemical Name Synonyms CAS-No. Concentration (%)
Distillates (Fischer -
Tropsch), heavy, C18-50 –
branched, cyclic and linear
Distillates (Fischer-
Tropsch), heavy,
C18-50-branched,
cyclic and linear
848301-69-9 0 - 90
SECTION 4. FIRST-AID MEASURES
General advice : Not expected to be a health hazard when used under normal
conditions.
If inhaled : No treatment necessary under normal conditions of use.
If symptoms persist, obtain medical advice.
