skaughtz
That’s it, yes it’s online, but if you call Mary Jane at (815) 932-3288 and order that way with BITOG15 promo code, not only will you get 15% off but you’ll also get $25 flat rate shipping for a case.
Alright. I like your moxie. I got the HPL Engine Cleaner. Three questions:
1) It says use 1qt EC to 5qts oil. My Camry takes 4.5qts oil with the filter, so is it safe to go with the full 1qt EC to 3.5qts oil, or should I actually proportion it out?
2) What is it in the EC that is so much more effective than Lucas or any other type of additive? Does it contain polyetheramine or something similar whereas the others do not?
3) It occurs to me that replacing 1qt of oil with the EC would still dilute the oil unless the EC has some fancy additive package as well?
The advice is appreciated.
