Leave it to TallPaul to bring up the grinding compound guy....everytime!
Yes,,,Just like mixing green Castrol with gold Castrol will cause a terrible color clash.Really bad!!quote:
Originally posted by Dad2leia:
If both base oils are 30 weight rated, where would there be a clash?
You should be fine. Your assumption is probably correct, although as a practical matter, I think you'd be hard pressed to define any real functional boundary between a pure fill of 0w-30 and the soup that you're proposing. The 5w-30 itself is a great cold weather oil in its own right. It's not as if you're dumping a couple qts of straight 60 wt into your 0w-30, afterall.quote:
Originally posted by pbm:
I was thinking of adding 1.5 qts of Mobil 1 5w30
to the remaining 3 quarts of Mobil 1 0w30 that I have left for the winter OCI. Is it safe for me to assume that I'll have somewhat better cold weather properties than a 5w30 but not quite as good as if I used all 0w30?
Maybe I should contact the dealer and tell him the oil he sells doesn't exist. It is a Nissan and Nismo specified oil. It exists, maybe not in SAE land. Plenty of references to it if you do a google search.quote:
THERE IS NO SUCH THING AS 7.5W OIL!
Just tell him it's falsly labeled.quote:
Originally posted by theguru:
Y_P_W said
Maybe I should contact the dealer and tell him the oil he sells doesn't exist.quote:
I didn't want to get that specific at the time. That would only have lead to bringing up obscure weight classifications such as bantamweight or cruiserweight. And what the heck does "super flyweight" mean?quote:
Originally posted by mechtech:
ypw - Flyweight, welterweight, and light-heavyweight are all legitimate categories, as well.
quote:
Originally posted by serious II.5:
Thanks for the information, advice, and chemistry lesson. It looks like it would be best if I did not "cross-blend" different brands.
I had been tinkering with a blend of Mobil and Valvoline which gave me "Mobiline". Havoline and Formula Shell gave me "Hav-****" . However, I got very worried when I mixed Castrol and Quaker State and ended up with "Castrate". Then I knew that I was in way too deep . . .
quote:
Originally posted by Camu Mahubah:
The base oil of a 10w-30 is compared to a 5w-30 denser, of larger molecules, higher viscosity. However you want to say it the 10w-30 is heavier than the 5w-30 at less than operating temperatures.
This is why oil floats on water. It is less dense than water. The 5w will "float" on top of the 10w. Larger molecules sink to the bottom.
This will occur until the oil pump mixes the oil, however when the car is shut off the 10w being denser will "sink" the 5w being lighter will "float". I have tried to make this a simple as possible.
You will not have a 7.5w-30!!!!!!!!!!!!!!!
