All true but still it made me distrustful of the ecore's failure mode if the filter bypass is not working. And it also makes me consider if the filter could develop 70 psid or more, then the media they are using is possibly more restrictive than some other filters. Cheap filter media with high efficiency would tend to be restrictive.
Anyway you slice it, it doubtful a BBC pump would develop much more than 70 psi if that and so if the filter flowed anything there would not be 70+ psi ahead of the oil filter in the first place. I guess virtually 0 flow through the filter is possible, but it's the failure pattern. Metal end caps and center tubes wouldn't fail the same way.
