2016 Kia Soul what oil
by mailman74
7 minutes 54 seconds ago
Mom's Car Advice - Jeep Patriot
by Nick1994
49 minutes 35 seconds ago
Educate Me on Royal Purple
by CrackyWainwright
Today at 11:45 AM
Castrol Edge (Belgium) 0W-40 @ Walmart $25.97
by Ed_Flecko
Today at 11:27 AM
Old house questions (part 2)
by Nick R
Today at 10:58 AM
Trust older tire balancing equipment?
by Corollaman
Today at 10:46 AM
Jon J Riccardo,Iacocca Predecessor
by NHGUY
Today at 10:17 AM
Mobil "424" variation
by Lemioux
Today at 10:07 AM
2016 Malibu
by Tzu
Today at 07:47 AM
2011 Outback, Unknown Oil, 5K miles
by Al
Today at 07:13 AM
Mechanics of no-fault insurance
by Quattro Pete
Today at 06:10 AM
Classic Shell Start Menu
by GumbyJarvis
Today at 03:35 AM
Lemioux, Tsr71, SubaFool, dookchoppa, Formula413
56911 Registered Users
106 registered (andyd, 2002 Maxima SE, 1989outlaw, Bandito440, aquariuscsm, Atesz792, 9 invisible), 1751 Guests and 101 Spiders online.
56911 Members
66 Forums
244684 Topics
Page 2 of 2 < 1 2
#3399766 - 06/17/14 12:43 PM Re: So THAT'S why there's a wobble [Re: expat]
CapriRacer Offline
Loc: Somewhere in the US
Originally Posted By: expat
Right on!
I spent several years retreading truck tires, That is a casing separation.
Cut out the blister. It would be interesting to see what's underneath . I bet you will find Rusty belts.
I'm going to guess that the steel belt is in the way except at the tread edge. So Jack, if you do cut into it, start at the tread edge and cut horizontally into it - between thge eblts.
Oh , and rust inside is NOT a symptom as much as it is the result of the rubber peeling off the steel belt.
And, No, these are not typically adhesion failures. They typically start under the top belt NEAR the belt end, but within the matrix of rubber. It's a fatigue failure of the rubber.
CapriRacer
Visit my web site: www.BarrysTireTech.com
#3400008 - 06/17/14 06:09 PM Re: So THAT'S why there's a wobble [Re: CapriRacer]
expat Offline
Loc: Canada
Right on!
We would often see this if a truck was overloaded or had low tire pressure.
It was often thought that a small separation might start around a puncture to the belt depth (causing the belt wires to separate form the rubber). Water in the small separation might then be forced, under the tread, with every rotation, causing an ever larger separation.
We would normally see a lot of this after the first rain at the end of summer.
#3400284 - 06/18/14 02:24 AM Re: So THAT'S why there's a wobble [Re: Nick1994]
Darris Offline
Loc: Toronto, ON. Canada
The tire looks indented and shaved down in the middle - I thought that was usually from over inflation?? Although the outer blocks aren't exactly in good shape either... I wouldn't think 36psi is nearly enough of a deviation to account for that kind of wear though.
The Insignia was a very weak tire near the bottom of Bridgestone's line up and supplied as the factory fit on the base Corolla for a number of years. I would not judge any tire manufacturer based on a product for such an application.
'02 Nissan Altima 2.5L 2011-2014
'03 Nissan Altima 2.5L 2014-
#3400398 - 06/18/14 08:40 AM Re: So THAT'S why there's a wobble [Re: Darris]
CapriRacer Offline
I hope Darris won't think I am picking on him - even though he is kind of new around these parts. It's nothing personal, just a cautionary note concerning the way many people think about things.
What I want to point out is that the photos are all of the bulged out area. You just can't judge what the rest of the tire looks like by looking at that area - and it is the undisturbed portion that ought to be looked at to make the sorts of assessments he made.
And I would also caution making an assessment of inflation pressure based on wear. As a tire designer, I could alter the wear by changing the shape of the belts - and sometimes we would deliberately change it to improve rolling resistance, knowing that we were hurting wear. In other words, do NOT assume that center wear is caused just be inflation pressure.
CapriRacer
#3400583 - 06/18/14 12:33 PM Re: So THAT'S why there's a wobble [Re: CapriRacer]
Astro14 Offline
Loc: Virginia Beach
Capriracer, you are a great resource for the forum, I learn something from your posts often, but this one really surprised me....I had no idea that this was true!
As an example, with 50,000 miles on them, my Conti Extreme DWS in 235/45R17 are worn to the bars in the center, but still at 5-6/32 on the edge. I had run them at factory specified pressures (34 -38, depending on anticipated load) their entire life. I had assumed it was simply Volvo specifying too high of a pressure...now, I see that the issue is more complex...
32 Packard 15W40
90 4Runner 5W30 Edge
92 300E 5W40 LiquiMoly
02 Volvo V70 T5 0W40 M1
02 Volvo V70 XC 5W30 PU
05 MB S600 0W40 M1
06 Corolla 5W30 Edge
#3401101 - 06/18/14 11:26 PM Re: So THAT'S why there's a wobble [Re: CapriRacer]
Darris Offline
I hope Darris won't think I am picking on him ....
No, not taken personlly at all. I'll buy that form you as factual information.
But at the same time its kind of worrisome that you can't take for granted the observations which have been taught to lay people for years in car magazines and tire dealer websites (such as center wear=overinflation, shoulder wear=underinflation, random wear spots=alignment and so on.) I just assumed that engineers across the industry would agree to use models which resulted in wear symptoms presenting in ways consumers could become accustomed to identifying.
#3401198 - 06/19/14 05:33 AM Re: So THAT'S why there's a wobble [Re: Astro14]
supton Offline
Loc: NH
I used to run 40psi in several sets on my Jetta, wore nice and even. This past set though gave indication of premature wear so I dialed it back a bit. I was confused as it the same size tire--granted, I've had several different kinds. Interesting, never realized it could be yet another design parameter.
2011 Toyota Camry, base, 6spd manual, 107k, hers
2010 Toyota Tundra double cab, 4.6L, auto, 114k, his
#3401221 - 06/19/14 07:04 AM Re: So THAT'S why there's a wobble [Re: Astro14]
CapriRacer Offline
Capriracer, you are a great resource for the forum, I learn something from your posts often, but this one really surprised me....I had no idea that this was true!.....
Thank you for your kind words. It's why I do this
......As an example, with 50,000 miles on them, my Conti Extreme DWS in 235/45R17 are worn to the bars in the center, but still at 5-6/32 on the edge. I had run them at factory specified pressures (34 -38, depending on anticipated load) their entire life. I had assumed it was simply Volvo specifying too high of a pressure...now, I see that the issue is more complex...
No, not taken personlly at all. I'll buy that from you as factual information.
I put both of these quotes together, because they are related.
Treadwear on bias tires is more sensitive to inflation pressure than for belted tires. (which would include radials). Much of what people see regarding the affect inflation pressure has on wear is from that bias tire era. It isn't that what is said isn't true, it's just that the effect isn't as strong as it used to be.
2nd thought: Steer tires tend to wear in the shoulders (for obvious reasons), and drive tires tend to wear in the centers. In RWD cars (and trucks), you can see the difference, but on FWD's the fronts do both, so what you get is about the ratio of steering to driving - and usually they are about the same, so even wear.
I think the affect inflation pressure has on treadwear evenness is about the same as the affect steering/driving has on even wear. So what one gets is more a matter of which is dominating. One can get pretty much any combination, so it will be quite confusing for the average person to figure out.
And on a side note: In the sphere of consumer knowledge, things change very slowly. It can take a long time for an "Old Wife's Tale" to become a quaint, but unused bit of folklore.
Tires are no exception - and in some respects are part of the problem. People only occasionally pay much attention to them.
I'll give you an example. Last week I gave a deposition, and one of the lawyers pointed out that General Motors says in its owners manual that bias tires and radial tires should not be mixed on the same vehicle. Good advice, but it has been 35 years since GM offered a vehicle with bias tires on it - and for practical purposes, you can not find bias tires in the proper size, so why continue to have this recommendation?
And what about AWD cars? Some vehicles are very sensitive to rolling tire diameter, but the owners manual didn't reflect this until quite a few years AFTER this became apparent. Even today, it is hard to find the passage in the owners manual - and the average guy doesn't even know that it is there.
I could go on and on.
CapriRacer
#3401225 - 06/19/14 07:11 AM Re: So THAT'S why there's a wobble [Re: Nick1994]
Mr_Joe Offline
Loc: Wisconsin
My sister had a 'whobble' a few months ago, just after a shop took off Winter tires in MI. She asked a guy to look, he didn't see anything. Within 2 days of the wheel changes the wheel came off while driving. She was going about 30 at the time, damage was modest.
The shop owned up, still a few issues with proper repair.
#3401563 - 06/19/14 02:33 PM Re: So THAT'S why there's a wobble [Re: Nick1994]
ARB1977 Offline
Loc: North Texas
My Bridgestone Revos 2's are starting to cup. There are times you feel it and times you don't. I still have 6/32's left with 50K on them. Starting to get loud on the freeway.
Edited by ARB1977 (06/19/14 02:35 PM)
2002 Tacoma 3.4L 175K (as of 09-24-15)
M1 HM 5W30 / Toyota filter
2008 CRV 2.4L 138K (as of 12-06-15)
PP 0W20 / Fram Ultra filter
#3401684 - 06/19/14 05:39 PM Re: So THAT'S why there's a wobble [Re: Nick1994]
Nick1994 Online   content
Loc: Phoenix, AZ
I got Goodyears on order from Walmart. Can't beat $49 per tire for a name brand. We'll see how they do
2000 Toyota Camry 2.2L 206k
Pennzoil Platinum HM & Fram Ultra
Page 2 of 2 < 1 2
