JHZR2
Staff member
Here is the oil pan from my 91 BMW 318i with about 110k. I dropped it because some folks on the M42 forum I frequent had been seeing problems where the upper oil pan bolts were working loose and falling out. If enough fall out, there is the potential for the gasket between the upper oil pan and the block to shift, causing the oil pump to suck air... I had to do an OC, so figured Id pull the pan while I was at it, remove the bolts, thread seal and re-torque them.
None had fallen out... two were completely loose, one was easy to turn with just a finger, and the rest were OK.
Here is my oil pan and pics looking inside the engine from underneath:
The last two really arent that color. The metal is clean as can bee silver, the oil was amber, and I shot with flash and high iso settings on a P&S, and got this yellow tinge to the metal. Everything is VERY clean.
I did run Auto-RX just before this change, look at how the gunk in the pan is loose and mobile...
JMH
JMH
