- Joined
- Aug 28, 2006
- Messages
- 2,326
You don't know how to read or your severe case of fanboyism blinded you, or both. Furthermore, you are disingenuous for only quoting a snipit.
Question: “Does Mobil 1 have less oil film strength than Royal Purple? I have seen many times the friction test of oils using the machine that tests the oil film, test result shows that Royal Purple has more friction protection that Mobil 1 does, seeing these results makes me think that Mobil 1 is lacking some benefits, therefore Royal Purple has the better protection of all.”
Answer: "There are certain oils in the market today that use EP (extreme pressure) additives in their engine oil that are really designed for gear oils and not engine oils. Extreme pressure additives are typically not used in engine oils for a number of reasons, but the most important reason is that they can cause engine corrosion over time. The rigs being used in these demonstrations are primarily designed for industrial applications like gear oils where extreme pressure is a necessary and important performance feature. These demonstration rigs have very little to do with modern engines, which is why market leading oils in the industry perform poorly in these tests."
Good luck with Fram.
Originally Posted By: jk_636
Summary of Mobil 1s reply: Royal Purple is better (as verified through testing) but they could cause corrosion (unverified accusation). you heard it here folks, it came straight from the horses mouth. If you want a good oil, use M1 if you wan the best oil, RP is just a short drive away. now that I have had my point substantiated, everyone on this forum who doubted RP owes my an apology, or letter of surrender. Your own company admitted it. And now that I have tackled this challenge, it is time to take on Fram...
