D
Deleted member 89374
This video is a deep dive into the differences between Pennzoil Ultra Platinum oil and regular Pennzoil Platinum oil. Mr. Lake Speed Jr., a certified lubrication specialist, uses a variety of tests to analyze the two oils. The key takeaway is that there's no difference in viscosity, but there is a significant difference in oxidation value, with Ultra Platinum oil having a lower value.
The Ultra Platinum oil boasts of "extreme protection", a claim that is substantiated by the presence of higher levels of calcium, magnesium, zinc, phosphorus, molybdenum, and boron. These additives and detergents, particularly the borate ester, are responsible for the oil's friction-reducing properties. Mr. Lake Speed Jr. uses an infrared trace test, F-T-I-R, to identify these esters.
The video also touches upon the differences between conventional and GTL base oils. The GTL base oil has a narrower bottom than the conventional base oil, and the ester spike in Pennzoil Platinum is likely a borate ester, which provides extra wear protection when combined with other additives.
In conclusion, Mr. Lake Speed Jr. is convinced of the superior properties of Pennzoil Ultra Platinum oil and plans to use it in his Porsche. He promises to share his experience in a future video, encouraging viewers to subscribe to his channel. The video is a comprehensive analysis of the two oils, providing viewers with a clear understanding of what makes Pennzoil Ultra Platinum oil stand out.
