Originally Posted By: qdeezie
Rear drum brakes should be outlawed. I hate them. And that's me being nice about it.
I know several car guys who hate rear disks, after doing a "simple" rear disk brake job and ruining a caliper or two because they didn't understand the wind-back feature (dictated by the need for the parking brake).
Originally Posted By: Miller88
Of course, economies of scale, save $20 a vehicle and that adds up. Why does Honda still use a timing belt on the J35? It's slightly cheaper than outfitting the engine with a chain.
There's much more to it than that. For one thing, it's a cheap/easy job, especially if you have an impact wrench to take off the crank bolt. If you really think you love chain driven engines, try to change the water pump on a Ford 3.5L V6. I'll do my J35 WP and you do the Ford... and I'll give you an hour head start.
Belts are quieter. Since they need no lubrication, casting and packaging issues are better. Inspection is easier/cheaper. Take a look at the valvetrain. The J35 engine designers obviously did not shy away from complexity. There are good reasons to use belts and it's not like J35's suffer from premature belt failures.
You've repeated this anti-belt rant as if you have some kind of point, but you don't. I suppose you resent a multi-hundred dollar scheduled maintenance. Perhaps you yearn for the days on OHV engines when it seemed like chain drives lasted forever. I would, except they didn't. At least, not for me. The nylon gear on my 351W broke down (as they always do) and I had to get a tow and replace it. My Fiero didn't even have a chain or a belt, but it broke down at 86K miles and I had to get a tow, and I replaced the broken Phenolic Resin Composite gearwheel.
Go to Reddit justrolledintoshop and see the horror pictures of chain drive DOHC service, lots of VAG and Mercedes owners [censored] about big shop time hours, and even ones with chains in the back against the firewall (again, Ford. Thank you, Ford, may I have another?).
For me, I'll take the performance and economy of an all-aluminum 4VPC engine with the simplicity of changing the belt myself. It's no harder and only a little more work than replacing a water pump on an old OHV V-8, something I've had to do many times.
