The 98 is a phase one engine and I didn't realize the TB change interval was 60K. My 2000 is a phase two engine and the TB change is 105,000. My mistake. Ed
Quote:
It has a studder between 1 and 2 gear and 2 and 3. IT does not catch and then jerks you a but. IT is just not smooth. IT is actually bettr if you get on it and drive fast thru the gears. SLower and it is worse.
Quote:
I just recently changed the front and rear diffs to Mobil 1 75W90 syn ... made a big difference. Before, I'd get a bit of a shudder or bucking motion when I'd leave off the gas and then again when I accelerated. The Mobil 1 stopped it completely - amazing.
In manual transmissions, yes, the gear oil for the front diff is shared with the transmission. For automatic transmissions, the front differential has a separate GL-5 gear oil; it does not share the ATF (because it is hypoid style differential; it is not a transverse mount like most FWD transaxles).I thought that the front diff. in a subaru was fed by the transmission oil???
I would stay away from aamco. You would need to find a known honest reliable trans shop which can be difficult. Ideally they should be familiar with Subaru or Japanese or import vehicles.
